Old 08-19-2005, 08:41 AM   #1
TN70C10
no dash lights
My dash lights all quit working about a week ago. I checked all the fuses and decieded to go ahead with a headlight switch. The switch fixed my dome light which hadnt before but still no dash lights. Any ideas before I start pulling the cluster out?
TN70C10 is offline   Reply With Quote
Old 08-19-2005, 11:21 AM   #2
JimKshortstep4x4
Talking
Did you check for power at the fuse with the headlight switch on? Also, I would try replacing some bulbs before pulling the dash panel.
Jim
Old 08-19-2005, 12:14 PM   #3
thecatseye66
'68 C-20 396 CST CC
thecatseye66's Avatar
Mine did that a while back too. I replaced all the dash lights with the brighter versions (168 ? I think) and just cleaned all the connections on the circuit board and the switch and they work fine now.
I'm not sure what the cause was but I'm suspecting just a loose or slightly corroded connection somewhere.
Good luck!
68 C-20 396/TH400 CST Custom Camper NOW W/DISC BRAKES
01 Jetta Turbo Daily Driver
84 Yamaha Virago 700 - Alaska to Florida Via Maine & Mexico
thecatseye66 is offline   Reply With Quote
Old 08-19-2005, 01:36 PM   #4
Try your dimmer switch. It is part of the circuity. Normally only messes with the headlights, but with enough corrosion who knows. Mine didn't work when I bought it, but that was because all the bulbs were burnt out.
Old 08-19-2005, 01:40 PM   #5
HeavyD
HeavyD's Avatar
I had them all burn out at once..must have been a short or something. Checked everything else out and finally replaced all the bulbs..worked fine after.
"You can take the man out of PA, but you can't take PA out of the man"
HeavyD is offline   Reply With Quote
Old 08-19-2005, 01:51 PM   #6
TN70C10
Ill check out the bulbs then. I just didnt think they would all blow out at once but ive seen stranger things happen. Come to think of it, they went out when I installed a radio. I may have shorted something out or just unplugged something by axe a dent. Thanks, will post when I find it.
Old 08-19-2005, 04:23 PM   #7
pjmoreland
pjmoreland's Avatar
There's a little ground wire that clips to the back of the dash. I'm not sure if it has anything to to with the bezel lights, but you could try wiggling it a bit to see if it makes a difference. It should be clipped onto the metal sort of behind the oil pressure gauge, if I remember correctly.
pjmoreland is offline   Reply With Quote
Old 08-19-2005, 10:23 PM   #8
1972ChevyCheyenne
That clip provides the ground for the dash. That where i would look next. Move it around to clean it a little. Hope that works for you.
Jamie
1972ChevyCheyenne is offline   Reply With Quote
