Old 08-20-2005, 09:46 PM   #1
CG
BlahBlahBlah
3/4 ton lowering and wheel choices
ive looked at a few vendor sites but havent had any luck yet. im looking to see if i can lower my 72 3/4 ton a few inches front and rear while still keeping the heavy dutyness (new word ). its coils front and rear. anyone done this? also ive been looking for custom wheels and finding only in 16 inch. does anyone have any experience here? all 3/4 ton wheels are 16 inch (or larger)? thanks
Old 08-20-2005, 10:31 PM   #2
DTerry
'70 GMC C-25 LWB
DTerry's Avatar
I am by no means a pro so if I am wrong please correct me.
There isn't as much choices with rims for 8 lug compared to a five lug trucks but there are some available. I think there is some at summit if you didn't check that. Are you looking for less then a 16 or more? Go here
http://www.discountedwheelwarehouse.com then click 8 lug on the left.
I haven't bought any thing from them but they have many 8 lug rims in all sizes.
As for the lowering goes I think you could use blocks in the rear (if you only want 2-3in) as for the front you can cut one coil off for a 2in drop. That should be the cheapest way to go if you only want a small drop. Or you can go with Drop spindles in the front (got mine at GMCPauls)and they keep it 3/4 ton and converts to disc brakes if you don't have them.
Hope this helps.
100th post
1970 GMC C-25 LWB (middle of frame up)
5-7 drop with 3in drop spindles, flip kit with blocks and still keeping the 3/4 ton. Shaved drip rails and marker lights, rear roll pan, cowl induction hood.
1987 Camaro z28
350, vortec 305 heads. 10:1 comp, t5 trans. Street terrrorizer.
1988 Monte Carlo (Super Stock ashpalt race car)
My Truck
DTerry is offline   Reply With Quote
Old 08-20-2005, 11:57 PM   #3
CG
BlahBlahBlah
i saw some nice ones at summit but all were 16 inch. im thinking the 1/2 ton spindles are different. i could be wrong on that though. cutting springs is always an option but 3/4 tons are rougher riding as it is and i bet if i cut coils it would be pretty bad. the rears are also coils im not sure you can do blocks with those. i will keep looking. and just so you know 71 and up come with the disks. i do appreciate your input thanks and congrats on number 100
Old 08-21-2005, 01:22 AM   #4
KAILUAZ
King of Rust
KAILUAZ's Avatar
Im in the same boat, except I have leaf springs out back. I too have been looking for 8 lug rims that are "old school" looking. Most all 8 lug are 4x4 looking. Whats our spacing 6.50 inch?
These are the ones I like the most from Summit; H/T Comp Series Vector Wheels
1970 GMC 2500, 350, TH400, front disks, thats it!
My Pics
KAILUAZ is offline   Reply With Quote
Old 08-21-2005, 01:43 AM   #5
67_C-30
I have a radical idea!
67_C-30's Avatar
Here are few Old School 8 lug wheels...
here is the link: http://www.akhwheels.com/
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 08-21-2005, 08:08 AM   #6
Boog
laying low
Boog's Avatar
CG. You need to check out Special 70 GMC's truck. C 20 lowered with wheels and paint. See the thread below about a repaint.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 08-21-2005, 09:44 AM   #7
FormerMember
There's a TON of 8 lug wheels out there.
All the major maunfacturers are knocking them out. Find the style you like in whatever wheel manufacturer, then call them for the 8 lug part number and order through Summit.
Most are 17" or larger.
Lowering is pretty easy. I called ECE for my 2" drop springs.
FormerMember is offline   Reply With Quote
Old 08-21-2005, 10:08 AM   #8
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Sure you can do lowering blocks in the rear on a coil spring truck. I've posted that picture of mine about a hundred times.
Also, theres a reason all the 8 lug wheels are 16 inch (or larger), look at the size of the brakes and hubs on your truck. The wheels have to be bigger just to fit over that stuff.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 08-21-2005, 12:32 PM   #9
Bob Moore
CG - One option is the the dropped lower A-arm from Charlies Drop Shop in Portland, OR (uses standard spindles). Another option is 3/4 Ton dropped spindles from Bell Tech(use to be available). Or lowered springs from ECE, etc.
Keep us posted on your progress - Bob
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
