Old 08-01-2005, 11:23 AM   #1
yank
yank's Avatar
Fuel tank opinions need
I'm moving my fuel tank under the bed in my 70 SWB and looking for some opinions on the different choices of tanks. I would like to have a custom aluminum tank made but that's not in my budget. I've considered a fuel cell from Jegs or Summit but would require more fabication in the fuel filler hose since I want to put the filler behind the marker light. I'm leaning toward a new suburban tank. What are your opinions on the poly tank verses the steel tank.
TIA
Mike
70 C/10 SWB
Go ahead chance it........Columbus did!!!
Steve (Chitlin) Bacon
My DIY Shop http://s24.photobucket.com/albums/c47/mpalmiter/shop/
yank is offline   Reply With Quote
Old 08-01-2005, 12:13 PM   #2
Joe67
67 is sold
Here are some options:
http://67-72chevytrucks.com/vboard/s....php3?t=117123
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 08-01-2005, 01:03 PM   #3
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
I have the blazer/burb tank, and Im running the filler in the wheel well with some marine hose, should be ok.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 08-01-2005, 01:08 PM   #4
71swb4x4
71swb4x4's Avatar
If you are putting it behind the marker a Blazer tank may be better than a Suburban. If I remeber right the Blazer exits a little further back. I am not positive if that's correct, it's been a while since I have seen a Suburban tank.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 08-01-2005, 01:40 PM   #5
bigblock73
yeller
bigblock73's Avatar
Here is a link to the article I wrote about the fuel cell I put in my '73. I understand the year difference, but the idea is the same.
http://www.73-87.com/7387garage/chas...ellinstall.htm
bigblock73 is offline   Reply With Quote
Old 08-01-2005, 02:07 PM   #6
yank
yank's Avatar
I meant a blazer tank. My bad.
mike
70 C/10 SWB
Old 08-01-2005, 02:32 PM   #7
jcfoote60
Active Member
jcfoote60's Avatar
I am right in the middle of my conversion on my 72 SWB. Not fun for sure, I chose to cut my bed sill down 2 inches (good info on this in the FAQs) and will be popping the fuel filler up behind the wheelwell in the bed using a design I also saw on the board. My blazer tank was an LMC and it has a short goose neck, however I have seen others out there with a longer goose neck that appears would go up and over the frame rail a bit easier. So there is more than one style of Blazer tank out there, at least at the gooseneck. I was wondering how everyone out there is venting their Blazer tanks? Fuel fill is covered but what about the vent tube???
jcfoote60 is offline   Reply With Quote
Old 08-01-2005, 08:32 PM   #8
71meangreenc10
Good Question
Smitty
71 C30 Wrecker
Old 08-22-2005, 03:55 PM   #9
72mdgmc
I am in a72 project and am using 79 pontiac bonniville tank/ with fill on side, also using 92 model sportside bed, using tank straps out of same car. fits on rear frame perfect and still will be able to use reciever hitch.
72mdgmc is offline   Reply With Quote
