![]() Join Date: Jan 2002
350 troubleshooting
My buddy bought a 69 chevy with a 350 in it. It was originally a 6 cyl. We can't get it to turn over, or anything to work(lights, etc.). We have changed battery terminals and the battery, still nothing. The starter doesn't "click" either. Please help...
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets 68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction 69 Chevy Camaro SS, 383, 4 speed, positraction 70 Chevy El Camino SS396, Triple Black, 454/th400, Tach 70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks 70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR 71 Chevy Blazer, CST, 350/auto 71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s 71 Custom/30, Open Road, 350/th400, tilt 72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi 72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi |
![]() ![]() Join Date: Jan 2005
Does it have a wire running from the + terminal of the battery to a little black block on the inside of the passenger side fender? There should also be a red wire connected to the black block that runs across the top of the radiator support. That red wire provides power to the entire electrical system.
hometown heroes!
check your battery cables, make sure that they are wired right, and tight.
2009 Silverado 2wd, 121k as of 04APR13. I love my truck 29 days out of the month. The payment is due on the 30th... ![]() Do your duty in all things. You cannot do more, you should never wish to do less. -Robert E. Lee "Never give up ground you've already taken." -Unknown |
![]() Join Date: Jan 2004
On that wire that runs across the radiator support are (2) inline fuses. One or both are probably the culprit. Good luck!
My Suburban Project 72 Suburban 68 SWB 57 Belair 55 Cameo 06 Chevy 1/2 ton crew 09 Suburban |
Make sure the gearshift is all the way to the left in park, mine does this sometimes. It will be in park but there is some slop in the lever so it needs to be all the way left.
Hope this helps |
Thanks all, it didn't have the wire from the positive battery terminal to the junction box. Fired up after that
Designated A-hole!
Glad to hear you got it running!
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
