Old 08-24-2005, 12:20 PM   #1
71-longbed
Its Magically Delicious
71-longbed's Avatar
vacuum fitting
im going to be converting over to power brakes .. im currently running a th350 .. so i've need a fitting that is shaped like a "T" to get vacuum to the tranny and the booster at the same time ... where should i pick this up and what size threads should i be looking for ??
thanks
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Of all my favorite things to do, The utmost is to have a brew.
My love grows for my foamy friend, with each thirst-quenching elbow bend.
Beer so frosty, smooth, and cold it's paradise pure liquid gold.
Yes beer means many things to me that's all for now cus I gotta pee.
71-longbed is offline   Reply With Quote
Old 08-24-2005, 12:29 PM   #2
Americanrider
The side that the booster runs off of should just be a simple barbed hose fitting that the booster line slips over and then clamped. Without seeing the tranny side line setup it's hard to answer that. A good place to start is a local hardward store.
Americanrider is offline   Reply With Quote
Old 08-24-2005, 12:42 PM   #3
demi
demi's Avatar
You could pick up something like this.
Ricks camaro parts, paragon, and classic industries sell these.
demi is offline   Reply With Quote
Old 08-24-2005, 12:43 PM   #4
Putter
More Cowbell....
Putter's Avatar
That is what I did (hardware store). I took my single port out of the intake and took it with me. Bought one that had two threaded ports in it (same size). I then bought two barbed hose fittings (as mentioned by Americanrider).....one for each size vac line needed. Voilla.....power brakes!
EDIT: while I was typing, the picture was posted above.....I like that better...gotta' check into one of those!!
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 08-24-2005, 01:50 PM   #5
4tiresngas
An American Soldier
4tiresngas's Avatar
Putter, what are barbed hose fittings. I have to find something. I have a monstrosity with 3 ports (1 - xmsn, 1 small plugged, and 1 huge one with a bolt stuck in it). I need to get something that will work. I have a 1988 350 in my 69 SWB Step. I like the Power Brake Inlet Manifold Fitting that demi posted, but I can not find it at Classic Industries or Ricks. Also, I'm not sure of the threading on mine, sine the manifold is newer. Thanks.
Dan
dan.brue@us.army.mil
4tiresngas is offline   Reply With Quote
Old 08-24-2005, 01:59 PM   #6
cdowns
cdowns's Avatar
any autoparts store
Old 08-24-2005, 02:13 PM   #7
72402
Normally, your booster vacuum is pulled from the base of the carburetor at the rear. If you don't have power brakes, there should be a 1/4" pipe plug in the hole. Simply remove it and screw in a barbed hose fitting. The port in the intake manifold where the transmission vacuum line hooks up is normally 3/8" pipe thread, some aftermarket manifolds may be different.
72 Cheyenne SWB Fleet/original 402, TH400, buckets & console
65 C10, 350TBI, 700R4 (work in progress)
72402 is offline   Reply With Quote
Old 08-24-2005, 02:19 PM   #8
71-longbed
71-longbed's Avatar
72402.. are you referring to a q-jet ??
demi : thats exactly what im looking for.. thanks
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Old 08-24-2005, 02:39 PM   #9
Putter
More Cowbell....
Putter's Avatar
Fittings that will screw into the intake, carb, etc.... and look similar to the picture below. You push the hose up and it is heck to get back off!!!!
Old 08-24-2005, 10:52 PM   #10
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
I've got a real one!
$15 shipped...if you want this one and don't have to chase all over trying to make something.
I just put one on an alum intake...see pics on here later on another post.
Email: frankeham@comcast.net
Phone: 360-956-7170
PICKMUP is offline   Reply With Quote
Old 08-25-2005, 12:37 AM   #11
tomatocity
tomatocity's Avatar
What do you use to remove and install these fittings?
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck.
tomatocity is offline   Reply With Quote
Old 08-25-2005, 01:14 AM   #12
4tiresngas
An American Soldier
4tiresngas's Avatar
PICKMUP...I got one out of a salvage yard today. Could not find it at AutoZone, Kragen, Parts Plus, or NAPA.
Demi...I still would like to have a new one. Can you send me the link to where you found that. I could not find it on any of those sites.
Thanks.
Dan
Old 08-25-2005, 03:51 PM   #13
demi
demi's Avatar
Here is one place that has them.
ricks camaro parts
I hope this helps.
4tiresngas - I sent you a pm.
demi
