Old 08-10-2005, 10:27 AM   #1
baumer
Body mount torque settings?
We just installed all new body mounts and the directions state that we should tighten them to the factory specs... any idea what the factory specs are for a 1970 Blazer?
Thanks...
baumer is offline   Reply With Quote
Old 08-10-2005, 10:49 PM   #2
mkundo
Tork setting are made on the size of the bolts used to fasten body to frame.
My .02 cents
mkundo is offline   Reply With Quote
Old 08-11-2005, 08:53 PM   #3
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
The assembly manual says 35-55 Ft lbs. Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 08-11-2005, 08:59 PM   #4
hilljob26
hilljob26's Avatar
go till its tight,then a nice grunt,that always seems to work for me
21 2500hd duramax
58 apache
HILLJOB GRAPHIX--for all your graphic needs
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=542497
LS ENGINE SWAP INFORMATION THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=377348
4l60 to an NP205
http://67-72chevytrucks.com/vboard/s...43#post3697343
hilljob26 is offline   Reply With Quote
Old 08-11-2005, 09:36 PM   #5
red71cheyenne
Back in the sticks
Hilljob's way will work too. That was the radiator mount torque. The last three mounts are 15-24 Ft lbs and I'm still looking for the number 1 mount. Jeff.
2011 K1500 Suburban
2014 K1500 Pickup
Old 08-12-2005, 12:10 PM   #6
baumer
Thanks for the numbers. We took gr 5's out and put gr 8's in. Just want to be sure we don't over do it.
Old 08-12-2005, 12:31 PM   #7
red71cheyenne
Back in the sticks
I don't know if you can overdo it, other than starting to pull the bolt head thru the floor. The only torque I can find on mount 1 is for pickups and it said 70-95 ft lbs. Anyone else pay attention to these settings? Jeff.
2011 K1500 Suburban
2014 K1500 Pickup
Old 08-12-2005, 04:07 PM   #8
baumer
Thanks for all of your help... that gives us a range to work with.
Old 08-24-2005, 08:46 PM   #9
awilliams65
How much trouble did you have changing the bushing out. Im gettign ready to do mine on my 72 K5. Just got the kit in and was wondering if there is anything I might need to know??
awilliams65 is offline   Reply With Quote
Old 08-25-2005, 07:53 PM   #10
Jimmy72custom
Jimmy72custom's Avatar
50 ft lbs for the one below the windshied, and 20 ft lbs for the others. Not sure about the radiator mount, but I think I went 35 ft lbs.
Jimmy72custom is offline   Reply With Quote
Old 08-26-2005, 09:28 PM   #11
red71cheyenne
Back in the sticks
The bushings on mine were pretty much rusted to the cushions, but I had new ones anyway. All the old crap went in the dumpster. Jeff.
2011 K1500 Suburban
2014 K1500 Pickup
