Old 08-26-2005, 08:34 PM   #1
Chevy_Man
Tightwad
Chevy_Man's Avatar
Need measurements of blazer tank!!
I am looking for the measurements for the blazer tank that fits the trucks best? Could some of yall help me out? I have a swb step side.
Thanks,
Eric
Chevy_Man is offline   Reply With Quote
Old 08-27-2005, 09:37 AM   #2
Huck
Huck's Avatar
Any 69-72 blazer tank will fit under any stock 67-72 truck bed but you will have to remove the spare ----hardware---and if fleetside, cut the lower portion of the floor support. they basically will bolt up to the frame between the crossmembers. You will need to decide where to arrange the filler. Pretty easy upgrade.
Huck is offline   Reply With Quote
Old 08-27-2005, 03:17 PM   #3
Deuce
Deuce's Avatar
I posted some pics on here somewhere entitled "Blazer tank pics" My truck is a 67 swb stepper.
I know what your thinking.......I have ESPN.
Sometimes it's easier to do things the hard way.
Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!!
Deuce is offline   Reply With Quote
Old 08-27-2005, 03:20 PM   #4
Deuce
Deuce's Avatar
http://67-72chevytrucks.com/vboard/s....php3?t=170017
Old 08-27-2005, 07:37 PM   #5
Old Yeller 1970
DON'T TREAD ON ME
Old Yeller 1970's Avatar
I pulled a tank off a '71 Blazer and mounted it under the bed of my '70 LBS. Later when the tank finally wore out completly, I replaced it with a JC Whitney tank which fit right up.
FWIW, I plumbed the fuel inlet out the rear of the left fender using the inlet and gromet from off the old Blazer. Looks like it was built that way.
Old Yeller 1970 is offline   Reply With Quote
