I'm getting a whinning noise thru my radio that is in relation to the engine rpm and I believe it is caused by the alternator. A suggestion was to install a "Radio Interference Capacitor". Since they don't cost very much I figure I don't have a lot to lose if it doesn't work. Only problem is I have no idea how or where to install it. Help please,
its all about the +6 inches
Install it on the hot wire, the one that has constant power. Also, find a better ground, normally that does a better job of 'cleaning up' the sound.
------------------ '69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it. FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite. If you need a pic posted, E-mail me at longhornmail@yahoo.com Andy, in Columbus Ohio |
![]() Join Date: Mar 2001
You can install both a 'capacitor' style
filter, but be sure and install one on both the +12BATT & the +12V-ignition....one or both of these could be a source of noise. Also beware that you may need to also install a 'choke' basically a transformer thing.. a coil of wire wrapped around a magnet of sorts "an inductor" Just make sure if you install this, to get one rated for the amount of current you device draws (amps). Moving the ground can also help...as well as making sure your antennna lead is not routed next to say the fan motor and that it too has a good ground at the fender mount. ------------------ 71 Chevy C-10 SWB Fleetside WAS:307w/3-on-the-tree NOW:350TBI/700R4/3.73 See it at www.prismnet.com/~grzanich
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi See it at www.prismnet.com/~grzanich |
Isn't there somthing for that built into the voltage regulator? Could be that needing to be replaced. Its a little piece inside the regulator case. I belive its a cylinder with a wire attatched to it. Maybe held down by a screw if I remember.
------------------ Nick Rodenberg Wellington, MO http://nickrod.port5.com You can click on "My 72 Chevy Truck" I have a 72 Cheyenne 10 with a V8 350 and a TH-350 auto-tranny. Ochre/White/Ochre Runs well... working on body. Plan to get painted weekend before memorial day weekend. Planned to be done March 7 when I turned 16. Didn't happen. Chose to do better job and be behind schedule instead of 1/2 doing it and it looking like junk.
Nick Rodenberg 72 Cheyenne 10 V8 350/TH350 white/ochre/white/ochre, ochre/saddle interior Retired and in the dry... still runs. I now drive Red '01 Ford Focus... better MPG!!! |
Where you buying the capacitors from?
69 SWB C/10 5-6 drop 700R4 69 Firebird Convert 455 4 spd 70 Torino GT Convert Austin-Texas |
I looked them up on Advace Auto's website. That's where I buy a lot of my parts.
Is your factory R.I.C still hooked up at the voltage regulator? it is mounted to the reg, not inside it.
71 Chevy CST Long Fleet 350/350/3.07 leaf rear. |
That R.I.C. is usually just a 1000uF capacitor in a metal can (aluminum, with
a wire coming out the center and a clamp or strap wrapped around the can, and it must be attached to a ground to make it work) If you go out junk-yarding, they are easy to find...on older cars, just look for one that is not melted/weathered too bad. But again, its just a heavy duty capacitor. You may still need to a 'choke' to your radio if its sensitive to alt-wine. ------------------ 71 Chevy C-10 SWB Fleetside WAS:307w/3-on-the-tree NOW:350TBI/700R4/3.73 See it at www.prismnet.com/~grzanich
| Bookmarks |
