Old 08-12-2005, 05:42 PM   #1
kbeefy
kbeefy's Avatar
adding power windows?
Thinkin about doing some power windows in my 70 'burb, has anyone done this? Any experience or advice on the different styles and kits available? I'd like all 4 windows and would prefer not to spend $600 to do it...
70 k20 'burban (latest aqusition)
91 k1500 xcab lb
99 f350 (sold)
83 cj7 (huge and for sale)
82 rx7 (auto-x project)
74 VW superbettle
04 summit 800 151 & 05 renegade 600
guns, flying, camping, biking, 4-byin, bbq's and beer!
kbeefy is offline   Reply With Quote
Old 08-12-2005, 09:06 PM   #2
Frizzle Fry
Frizzle Fry's Avatar
I bought some of these used on ebay for $40/pair. I am going to modify/adapt them to work in my '61. If that works out, I'll do my Burb the same way. I plan to use the new motor with the old regulators. We'll see how it goes...
Frizzle Fry is offline   Reply With Quote
Old 08-13-2005, 08:50 AM   #3
Hart_Rod
Hart_Rod's Avatar
Frizzle,
That's some awesome work on that 65. Keep me up to date, I'm doing some similar stuff to my '52 (http://67-72chevytrucks.com/vboard/s....php3?t=166465). When are you going to start on the burb, or is it going to be a weekend project truck?
Rob
Hart_Rod is offline   Reply With Quote
Old 08-13-2005, 11:04 AM   #4
Frizzle Fry
Very Nice! Looks awsome. The Burb is my DD for now and I do weekend projects on it (headers next!) I will dig deeper into it when the '61 is done. I may "Tahoe" it like this (further down the thead) -> http://67-72chevytrucks.com/vboard/s....php3?t=166940
Old 08-17-2005, 02:30 AM   #5
Swbman
Im going to put in some power door locks in my suburban, I will just use the power accessories out a late 70's early 80's burb or pickup, I know with a little time and patience I can get the the power windows to work as well, I'm kinda old school instead of buying a prefabricated kit, I would much rather go to my favorite boneyard, get needed parts and have my buddy give me a hand.
1961 BUICK LESABRE ** 1968 CHEVELLE SS 396 ** 1969 BUICK RIVIERA GS ** 1971 2 WHEEL DRIVE BLAZER ** 1971 4X4 BLAZER ** 1971 SHORTBED CHEYENNE FLEETSIDE ** 1971 SHORTBED 4X4 FLEETSIDE ** ...My Ebay
Swbman is offline   Reply With Quote
Old 08-17-2005, 12:07 PM   #6
kbeefy
kbeefy's Avatar
problem around here is the junkyards think they're the dealer, they charge new $ -10%. And they crush most stuff older than 10 years old.
91 k1500 xcab lb
99 f350 (sold)
74 VW superbettle
Old 08-21-2005, 08:24 PM   #7
hilljob26
hilljob26's Avatar
i bought mine for my truck here,might help
http://www.a1electric.com/index.htm
21 2500hd duramax
58 apache
HILLJOB GRAPHIX--for all your graphic needs
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=542497
LS ENGINE SWAP INFORMATION THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=377348
4l60 to an NP205
http://67-72chevytrucks.com/vboard/s...43#post3697343
hilljob26 is offline   Reply With Quote
Old 08-22-2005, 02:07 AM   #8
kbeefy
kbeefy's Avatar
thats one of the companies I'd been looking at, did you do this kit?
http://www.a1electric.com/Merchant2/...ct_Code=GM49-K
any feedback/opinions?
Thanks!
91 k1500 xcab lb
99 f350 (sold)
74 VW superbettle
Old 08-24-2005, 04:45 PM   #9
71sub
71sub's Avatar
I ordered 2 sets of these with their wiring kit and installed on my 71.
Here's the problem -- on the back 2 windows, one of the regulator arms is shorter. So, I had to cut the OEM short regulator arm and weld onto the new set, so that everything aligned. Does this make sense ?
If you have them removed, you'll notice what I'm talking about. It's an easy cut and weld ( measure 3x ), but not a "bolt-on" for the back two windows.
Ev
71 C/10 : 350 / 700r4 ; Ford 9" posi 3.50 with 31x10.5 rear tires, single drive shaft, C-notch, 2.5" drop spindles, keyless entry
71 Suburban 350/350 -- caddy tail lights, keyless entry, late model seats, billet Autometer instrument cluster
70 Ford Torino -- 351W (balanced & blueprinted ), C4, VDO gauges
71sub is offline   Reply With Quote
Old 08-26-2005, 02:11 AM   #10
kbeefy
kbeefy's Avatar
good info, thanks. Welding and fabricating isn't a problem... how's the kit work? Decent quality?
91 k1500 xcab lb
99 f350 (sold)
74 VW superbettle
Old 08-26-2005, 01:35 PM   #11
71sub
71sub's Avatar
Simply install --- rear driver window was a bit tight, due to space.
In regards to quality, good quality BUT the motors don't seem to be very strong. I have all new window rubber and felts, and since it's all pretty tight you can hear the motors "scream" the last inch or so.
Ev
Old 08-30-2005, 11:44 PM   #12
68plus4sub
68plus4sub's Avatar
I have a1 in the front right now.......thinking of doing the back the way of shortening the arm. Couldn't have been easier, and I haven't had any motor noise on mine so far....all my rubber and felt is new. We'll see how long the silence lasts!!
1972 Chevrolet Suburban ('68 front clip), 2wd, 350/350, factory tilt
2008 Kawasaki Concours 14
1997 Harley-Davidson Soft Tail Custom
1948 Chevrolet Coupe (project)
1972 Porsche 914
68plus4sub is offline   Reply With Quote
