09-01-2005, 07:30 PM | #1 |
outta the car velocityboy
Bed Off (almost I Think)
Hey there,
Righto finally bit the bullet. Threw the truck in the garage & got stuck in. Have disconnected the wiring loom, taken out the 8 bed to frame bolts which go thru the timber (the big suckers with offset washers). The bed should just lift off now right???? Or have I missed something? Cheers Lee
..give it a turn here, take some wedge out there, we'll win some races... |
09-01-2005, 07:55 PM | #2 |
May or may not be a ground strap between the frame and box, might want to remove tailgate now to make it lighter if you haven't already, check for interference with rear bumper, and remove first if needed, but then you should be good to go.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
09-01-2005, 08:28 PM | #3 |
I pulled my rear tires off and lowered the back end as low as I could get it. It made pulliing the bed off and putting it back on a breeze.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
09-01-2005, 08:56 PM | #4 |
Hope you have some help, that sucker is gonna be heavy.
09-01-2005, 09:40 PM | #5 | |
