Old 09-01-2005, 07:25 PM   #1
jakeslim
Premium Level Member
jakeslim's Avatar
How do I remove Wipers at base?
I need to remove my cowl to paint, but can't figure out how to remove wipers at the base? I don't want break them! Anybody know the trick?
69 K5 CST stock- 350, 4speed
77 K5 - 383, auto, 6" lift, D60 front, 14b rear, 39" tsl's,
jakeslim is offline   Reply With Quote
Old 09-01-2005, 07:54 PM   #2
AK|Bandit
AK|Bandit's Avatar
There's a retainer clip at the base of each arm. Kind of like the inside door handle. I cant remember what type of clip it is though. I do remember it was a pain in the butt to remove them. I think I used a set of small needle nose pliers. I'll double check when I get off of work...
It's better to wear out than rust out!
AK|Bandit is offline   Reply With Quote
Old 09-01-2005, 08:23 PM   #3
MOTHERTRUCKERS
Put a rag on the cowl and use a claw hammer just under the edge on the back side to pry up, hang on to the arm as it will fly off and scratch your paint.
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 09-01-2005, 09:41 PM   #4
matthufham
here i had this from a previous post
don't mind the blue marks. first push the clip in the direction of the arrow, and pry off arm in direction of it's arrow. more than likely it won't just come off, use pb blaster or oil and pull or pry hard. watch the paint on the cowl and you could bent the metal there if you pry too hard.
matthufham is offline   Reply With Quote
Old 09-01-2005, 11:41 PM   #5
jakeslim
jakeslim's Avatar
thanks responders I'll try it in morning. Trying to get truck painted by end of Saturday.
Been working on body all week
Old 09-02-2005, 12:50 AM   #6
72str8flush
72str8flush's Avatar
Although I am sure people have done it by pushing the clip up, my advise is to get this . I tried the same advise given here but none of it worked. I bought this tool and it came off in 2 seconds. The tool actually goes over the top so there is no danger of messing up the cowl (something I already had done before buying the tool ). Unfortunately, no local parts store carried so you might just want to order it online and wait if you can.
72 Chevy Short Bed Fleet: 350/TH350 - Sold - Now trying to sell the parts that I have left over.
_______________________
2006 VW GTI
72str8flush is offline   Reply With Quote
Old 09-02-2005, 09:52 AM   #7
junkyardjohn
junkyardjohn's Avatar
WHY ON EARTH WOULD ANYBODY USE THE PROPER TOOL FOR REMOVING THESE IN A COUPLE OF SECONDS, WHEN THEY COULD USE CHANNELOCKS OR VISEGRIPS, CLAW HAMMERS, PRYBARS, SCREW DRIVERS OR MY ALL TIME FAVORITE........ AN ENGINE HOIST & A SHORT PIECE OF LOG CHAIN. I USSUALLY GET THESE OFF IN ABOUT 20 OR 30 MINUTES, WITH MINUMUM DAMAGE TO THE HOOD, COWL, FENDERS & THE CAB. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 09-02-2005, 10:07 AM   #8
72str8flush
After trying both methods the getting it off in under a minute and having a beer is a lot better than grabbing needlenose pliers and cussing and grunting for a half hour. Choice seems obvious to me.
2006 VW GTI
Old 09-02-2005, 11:28 AM   #9
matthufham
i can do it in less than 5 (BOTH SIDES) with a tiny screw driver on the clip and a big screw driver or pry bar to pull the wiper arm off. and that was the 1st time i ever experimented with wipers, quite simple.
Old 09-02-2005, 12:17 PM   #10
thecatseye66
'68 C-20 396 CST CC
thecatseye66's Avatar
Sometimes those arms seem damn near welded on. I bought the remover tool from JC Whitney about 10 years ago and for 5 bucks I'd do it again if I lost the one I have. For that kind of money, there's just no reason to risk scratching up your cowl or shoving a screwdriver through your palm...
68 C-20 396/TH400 CST Custom Camper NOW W/DISC BRAKES
01 Jetta Turbo Daily Driver
84 Yamaha Virago 700 - Alaska to Florida Via Maine & Mexico
thecatseye66 is offline   Reply With Quote
Old 09-02-2005, 01:04 PM   #11
jakeslim
jakeslim's Avatar
Originally Posted by thecatseye66
....there's just no reason to risk scratching up your cowl or shoving a screwdriver through your palm...
can't wait to try removing this in a bit....unfortunetly i may will have to go the screwdriver through palm route
