Old 08-26-2005, 12:00 PM   #26
earl87gta
earl87gta's Avatar
I run a 6 in lift on my blazer with 3 body and I have had 38 on it I think I could have used 40 but never did. My new burb convertion Im going to use a 6in spring lift from a 73 up truck build my own hangers this should give me more lift then the 6in for ower trucks. In the rear Im going to use 2in springs and hangers from a 3500 the frames on the newer trucks ar taller and you and drop the hangers down a little to lift the back. just make sure if you do it this way that make a gussit for the hangers. Im also going to move the fron axle forward an in mabe 2 and the rear back an in or 2. hoping to have the new doner pannel or burb soon so I can get started over the winter.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 08-26-2005, 01:23 PM   #27
Gyva
Gyva's Avatar
6 inch super lift, 3 inch body lift 40X17X15 Ground Hawgs tires, never rubbed once. On one side (passenger front) I had to hack off some inner fender. But I've twisted the heck outta the frame going through ditch's and climbing over rocks... doesn't rub....
Mike
Gyva is offline   Reply With Quote
Old 08-27-2005, 12:12 AM   #28
2wdBlazer
The Blazer King
2wdBlazer's Avatar
Mike
Of course yours won't rub. You have huge cut out flares.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest.
2wdBlazer is offline   Reply With Quote
Old 08-27-2005, 01:51 AM   #29
Gyva
Gyva's Avatar
I don't believe they are cut, the guy that installed them said they just fit??????
Mike...
Old 08-27-2005, 02:27 AM   #30
1FaastC10
1FaastC10's Avatar
Mike...
you were lied to. look at the pic of your truck, and then of a stock one. obviously cut.
1FaastC10 is offline   Reply With Quote
Old 08-27-2005, 03:51 PM   #31
Gyva
Gyva's Avatar
crazy... ok 3 inch body, 6 supension and bushwacker cut outs.... went and looked at truck from inside the fenders and only the fronts are cut.. the backs are untouched
so maybe this is where the confusion happend... but on the front only the grille side are cut the rear half by the door are not cut,,,, I can take pics???
Mike...
Old 09-04-2005, 12:53 PM   #32
rich-white
OK I'll put my two cents in too. Also keep in mind that what WHEEL you use will make a difference. If you run a narrow tire on a 8.5 rim you may not nned as much lift and if you go with a wide wheel 12" or 14" this will "fan" the tire out making it wider and a little shorter so keep this in mind as your comptemplating your decision. If you go with the wider this will give your truck more stability with the wider footprint.
rich-white is offline   Reply With Quote
Old 09-04-2005, 12:54 PM   #33
rich-white
Cut outs front and back. So Sorry. Been lied to again.
