09-04-2005, 05:03 PM | #1 |
The start of the $ pit!
Colapsing the column
I have seen the thread about installing a tilt wheel and will do that as soon as mine arrives but I had a question in the mean time.
Can you colapse the column to any dimension you choose? I'm sitting too close to the wheel. |
09-04-2005, 05:26 PM | #2 | |
09-04-2005, 06:05 PM | #3 |
To answer your question yes within reason. The limiting factor will be clearance for the N\S switch. The part that is collasped is the intermediate shaft. See here:
http://67-72chevytrucks.com/vboard/s....php3?t=133937 If you place the N\S switch right on the van column you should be able to get as much room as you want again within reason. See here: http://67-72chevytrucks.com/vboard/s...threadid=63328
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
09-04-2005, 06:07 PM | #4 | |
