Does this look like it's on right??
I think it is, but a few extra sets of eyes would be reassuring.
![]() ![]() ![]() ![]() ![]() You can't believe how happy I am to be at this point!!
- Greg |
needin' money
i don't know, but the color on the spindle don't match
SWB Stands for Short Wide Bed |
Happy to be here
![]() Join Date: Mar 2000
No something is wrong there. It's supposed to be all greasy and dirty. That clean painted stuff won't work at all....
I would have to say that your going to get a hard pull to the left when applying the brakes.
AttentionDeficitDisorder
looks awesome
the headers r to shiny the motor is to pretty and clean there not hubs for the wheels or shocks so i think u need them to drive around j/k lookin badazz
http://img.photobucket.com/albums/v5...ropped/sig.jpg |
#7 | |
Looks great nice job Steve |
Izz to clean! Why can't mine be clean?! Nice. *tu*
1966 Chevy C10 longbed stepside 350/350 1981 Chevy Custom Deluxe C10 short fleet 305/350 |
Thanks for the props guys. I am soooo sick and tired of prepping and painting parts!! I just want to get this thing bolted together and drive it. But unfortunately I have a long ways to go before I can do this
- Greg |
Chevys Kick A$$
Looks too clean, but other then that it looks sweet. Coming along pretty damn good!!
What else u gotta do to get it driving again? -Later
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold ![]() -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit ![]() ![]() -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER ![]() I would rather push a Chevy then drive a ford!!
Until Seventy Times Seven
Looks good to me... and very clean.
![]() Good job. Have you torqued the shafts yet? I don't see too much thread showing? BTW, do you know if you can modify a stock brake shield to work on a drop spindle? Again, looking good. ![]()
boxRODz 1983 C10 SWB Fleetside When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son. You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin... |
#12 | |
Not sure on the brake shields. I had BellTech spindles years ago on a different truck and don't remember having to modify anything. But I will check it out and follow up with a pic tonight.
- Greg |
Born a Chevy Man
Looks like you are doing a great job there. Clean is good. It will be nice when you get it done and you can say "I did it". Getting to drive it and getting all the thums up is not bad eather.
John or 86 (Viet Nam combat Vet-BIG RED ONE) '65-'66 *1986 Chevy SWB Silverado *1984 Chevy Longbed Silverado New Kia Sportage (Wife's car and she loves it) ![]() ![]() If you can read this, YOU NEED TO THANK A TEACHER! If you can read this in ENGLISH, PLEASE THANK A SOLDIER! ![]() GOD BLESS AMERICA AND BLESS OUR FIGHTING TROOPS |
#14 | |
STILL PLAYS WITH TRUX
![]() Quote:
It's so simple to disassemble it now and you havent spent 60 bux on an alignment. But when the truck is on the road again you wont want to do it. Also for who ever asked about having to modify the dust cover plate i didn't need to modify mine and i used belltech spindles. |
#15 | |
![]() ![]() And here is the dust shield installed, no mods required. Notice the ARP stainless steel 12 point bolts. ![]() ![]() Incidently, one of my original dust shields was mangled. I got a replacement from the junk yard. When I was cleaning them up to paint them, I noticed the newer one is much thinner steel than the original. Evidently this was a 'cost reduction' sometime after '77. And BTW, the new one was noticably lighter than the old one.... hmmmm, less unsprung weight. ![]()
- Greg Last edited by 454HO; 09-04-2005 at 12:28 AM. |
#16 |
Here it is complete with rotor, caliper and shock.
- Greg |
#17 |
what are the torque specs all of the front end parts???
#18 |
Looks GREAT just a shame you have to get it dirty when you drive it. Keep up the good work and don't forget the pictures as you go.
Art
This is my best friend |
#19 | |
LCA shaft U-bolt - 85 UCA shaft nuts - 70 control arm rubber bushings, all - 140 UCA ball joint nut - 50 + additional to line up cotter pin, do not exceed 90 LCA ball joint nut - 90 + additional to line up cotter pin, do not exceed 130 Sway bar mounts, all - 25 shock upper - 140 shock lower - 60 brake splash shield to knuckle - 10 caliper mounting bolt - 35 wheel bearing preload - zero wheel bearing end play - .001" to .005" And if you had the crossmember out: crossmember to side rail - 65 crossmember to bottom rail - 100
- Greg |
#20 |
That looks awesome!! Looking at those pic's i noticed your LCA are not lipped or trimmed for wheel clearance.
I dont know what size wheels you plan to run but you may need to go back and trim that lip off. |
#21 |
I hope I can use the Impala SS wheels I have. They are 17"x8.5" with 5.06" backspace. I may have to use a spacer to push them out a bit.
I need two more parts to finish up the steering/suspension. The centerlink and the bracket or 'post' that the idler arm pivots on. I threw my originals away when I stipped the truck thinking I would replace them with new parts. Problem I'm finding now is you can't buy them new. If anyone has these for sale, please let me know.
- Greg |
#22 | |
yeller
BTW - your progress pics are awesome!! Keep em coming. ![]()
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
#23 | |
#24 | ||
![]() SS bolts ![]() ![]() BTW, are you looking to p***t the shock absorbers?
