Old 09-03-2005, 02:31 AM   #1
richardwilken
3/4T 4x4 spring lift and rearend change
Hi guys. Im planning to drop a 1977 14bFF under the rear of my 69 K20. At the same time, I am going to get 2 inch aprings made for all around the truck. What kind of geometry issues will I run into. Someone needs to write a rearend change FAQ. Thank you all
69 chevy 1/2 ton 2wd
72 GMC 1/2 ton 2wd
richardwilken is offline   Reply With Quote
Old 09-03-2005, 09:02 AM   #2
Yukon Jack
Yukon Jack's Avatar
The spring perches will need to be moved and you will need a conversion u-joint for your driveshaft. I don't know if the driveshaft length will actually change. My info on the u-joint conversion is at the office but someone will probably chime in on what it is.
You could PM Beast388 he has the specific info.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 09-04-2005, 11:26 PM   #3
454_72_4X4
454_72_4X4's Avatar
Curious...Did the 69 K20 use a smaller U-joint than a 72 K20? I had to move the spring perches also, (they were 1 spring width to wide on the 14FF), but I used the factory U-joint I think. It's been a few years though.
72 C20 4X4 454 4 speed
89 Trans Am (was) 305 TPI 700r4
93 C1500 2wd Extended cab 350 700r4
98 Sonoma (TPI outa the Trans Am)
03 Yamaha 660 Raptor
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
454_72_4X4 is offline   Reply With Quote
Old 09-05-2005, 01:09 AM   #4
richardwilken
what is the factory angle that the front and rear differentials are set at? If I use 2 inch lift springs, maybe someone better at geometry could figure out what the new angle would be.
72 GMC 1/2 ton 2wd
Old 09-05-2005, 02:01 AM   #5
full foot notch
the 3/4 ton ujoint is proly gonna be a 1350, and the 14bolt axle is prolly a 1ton/1410 series, in which a conversion ujoint(like neapco, PDQ, fed mogul) of 3-3130(or maybe 3-3150) which one set is 1350 caps and the other pair of caps is 1410 caps)
full foot notch is offline   Reply With Quote
Old 09-06-2005, 09:00 PM   #6
Beast388
Suburbans RULE!
Beast388's Avatar
The 14BFF uses a 1350 u-joint. Your original K20 driveshaft "should" be the 1350 as well. I had to use the Napa #348 conversion joint since my burb was a 1/2 ton.
The 14BFF in my Burb is also of the '77 variety. You will need to move the spring perches from the 42.5" spacing to the 40" spacing your '69 K20 requires. You will also need to move the shock tabs to the "both forward" configuration at the correct spacing.
Let me know if you want to see some pics and I will post them.
--Ben
71 GMC Suburban 4X4
The "Beast"
388 CID Stroker, TH350, NP205, 8-lug D44, 14BFF w/ Detroit, 4.10:1 gears, 4-Wheel Disks 4" Lift, 35" MT/R's.
Beast388 is offline   Reply With Quote
