462 double hump heads f/s $300 shipped u.s.
I have here a set of 66 327 heads,1.94 intake 1.50 exhaust and have had a recent valve job on them,they will need to be surfaced very little,slight pitting on the corner in last pic,nothing deep,just enough that i would say less than .010 would fix them up,mabye not even that much,i traded a good friend a running car for them,just trying to get something out of them. I nice matching pair of heads...
Those would be made for 1967....300hp 327 or 300hp 350........
TTT yes dated for a 67 model year...k-10-6
Nothing like adding 1.0 to the compression ration.....PERFECT for those dished piston 350's!
Yes they will fit,you just need a aftermarkes alt bracket for the early cars,any advance auto or autozone has them on the shelf....You can both them right up...will work great..i have all big blocks but one and just dont need them..
A mild built 350 with a mild cam should run a 600 cfm single feed,I run all edelbrocks on mine,I would say you are getting way to much gas with that carb...Try a 600 eddy and it will make a hugh difference,they are not that much . The gas saving over time is enough to get one..This carb will double the power you have and run R44T a/c plugs... Add a hei curve kit in the dist and a 77 corvette vacume advance unit...Will gain you about 35 hp....
![]() Join Date: Aug 2001
Do they have accessory holes?
#8 | |
User #12137
![]() Join Date: Apr 2004
Thanks robb yes no accesery holes in them....pre 68 car heads...
#10 | |
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
Any takers before they go to ebay?
