#26 |
How much did that fuel pump cost you? link? are you happy with its performance?
I got a line on a ls-1 for 1k with everything, obviously going to need to do some upgrading in the fuel department. -Cameron
1972 Dark blue, Cst, Highlander |
#27 | ||
Active Member
I got the "complete TPI setup" from a guy over on Thirdgen.org. Apparently "complete" is a relative term. I ended up having to buy a few more sensors and make some repairs to the harness. I opted to go with the stock harness. It was kind of a pain in the a$$ and took a bunch of time but it save a few hundred bucks and I learned a lot about the system in the process. All of the misc. parts I got from either Summit, Rockauto.com, other guys on Thirdgen.org, or the local parts stores. I've got all the reciepts but I haven't added them up yet....I'm kind of afraid to. I'm guessing it'll total in the $1200 range. Maybe one of these days I'll make up the parts list and post it. My best advice is to find a complete Z-28 or T/A and pull the thing yourself. That way you know you're getting everything in good condition. This swap (like most) can nickel and dime you to death. Go for it!! Mike
The rides: '72 Blazer 350/4spd/Tuned Port Injection '69 Firebird 400/4 speed 2001 Dodge Dakota Sport 4X4/4.7L V8/5 spd/Headers/Jet Chip, etc. Daily Driver 2002 Airborne Zeppelin (roadbike) Titanium frame/Campy Chorus 2004 Filippi Italia S (rowing shell) |
#28 | |
Active Member
Mike
#29 |
![]() Join Date: Aug 2005
Hi, nice tpi set up. I'm doing the same and do I have a ton of ? Did you use the stock harness for the engine? Look like you went from MAF to speed density. Did you leave the stock sending unit in the tank? How much was the fuel pump set up? What trans are you using? I wanted to make things easy for myself , but the wife wasn't down with a 5K Ram Jet. So, I 'm going to start having my paychecks forwarded to Street and Performance. Thanks, Chris
#30 | |
Active Member
I was able to fit the Tanks Inc. fuel pump in and keep the stock sending unit in the original Blazer tank. You've got to be careful because right above the fuel pump is a cross member for the bed so there is only about 1/2" of clearance there. I got lucky! It was no big deal to extend the pump to reach the bottom of the tank...I just had to splice in about a 2" piece of metal. But, if you are going to use that pump I would get the folks at Tanks to make you one that goes about 3" deeper that you can cut back to make it fit perfectly. I've got the stock 4 spd trans and was able to get a speed sensor from Stealth Conversions that fit in between the trans and the speedo cable. Basically I decided not to take the easy way out and figured out everything for myself. It was a learning experience to say the least but now that I know how to do, the next one will be a piece of cake (if I ever convince the wife to let me get another project!). RyanB over on the CK5 site did a nice write up that helped a lot. http://coloradok5.com/forums/showthread.php?t=106209 Good luck. Mike
The rides: '72 Blazer 350/4spd/Tuned Port Injection '69 Firebird 400/4 speed 2001 Dodge Dakota Sport 4X4/4.7L V8/5 spd/Headers/Jet Chip, etc. Daily Driver 2002 Airborne Zeppelin (roadbike) Titanium frame/Campy Chorus 2004 Filippi Italia S (rowing shell) Last edited by MikeS; 09-06-2005 at 10:28 AM. |
#31 |
Quick question for ya, Mike! Which fuel pump did you use from Tanks Inc?
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
#32 | |
Active Member
#33 |
