Old 09-05-2005, 08:09 PM   #1
el curioso
el curioso's Avatar
Boost for bags
I was wondering what you guy's and gal's know about this air system ? Heres the LINK
el curioso is offline   Reply With Quote
Old 09-06-2005, 06:28 AM   #2
gostranger
65 suburban vortec 5.3 bagged
gostranger's Avatar
yes i have seen it work in person and i know doug the creator and it works!! if you are into air ride you know you run out of air pressure fast this system keeps you from running out of pressure the first 100 systems will be avaliable next month!!
gostranger is offline   Reply With Quote
Old 09-06-2005, 07:17 PM   #3
Frizzle Fry
Frizzle Fry's Avatar
So how does it work? It says it adds a 5gal tank.
Frizzle Fry is offline   Reply With Quote
Old 09-06-2005, 09:49 PM   #4
Frizzle Fry
My guess is that the 5gal tank is used as a reserve and it's plumbed so that when the compressor comes on it provides pressure/volume to the inlet of the compressor. Just a stab in the dark...
Old 09-06-2005, 10:42 PM   #5
bigred66
bigred66's Avatar
look it up on s10forum.com he is on there try this http://www.s10forum.com/forum/showthread.php?t=196766
Atom (bigRed66)
1966- C10
1995- Wide Body Talon
1987- Dodge Raider (4 sale)
2000- 4-door Nissan Frontier
2003- Ford Focus (wife)
bigred66 is offline   Reply With Quote
Old 09-07-2005, 12:02 AM   #6
Shane
Shane's Avatar
No real info on the website ... but by the description of it, it sounds like an accumalator type set-up. I could be wrong about that, but if it is an accumalator setup, then its not very complicated to build.
Shane is offline   Reply With Quote
Old 09-07-2005, 12:02 AM   #7
el curioso
el curioso's Avatar
What will be the price range?
Do you need to add another 5 gal tank cuz I already have 4-three gal tanks that I really like cuz they are polisheable steel. Can I just add the system to one of them?
What im trying to ask is if a special kind of tank is used?
Old 09-07-2005, 10:57 PM   #8
lv2whl
what i get out of the talk is that when you dump the air out of the bags, his system recycles that air into another tank and then when your compressor turns on after you fill the bags, it draws from an already pressurized tank. so basically its moving the air quicker.
Thats at least what i got out of it. myabe im wrong though.
-American Pride-
71 2wd k5 Blazer-under major construction
Anyone know of a 71 4x4 k5 in Nor Cal????
let me know- lv2whl@hotmail.com
lv2whl is offline   Reply With Quote
Old 09-07-2005, 11:47 PM   #9
Frizzle Fry
Seems to be the case. No need to buy a "system" for that. Just a little plumbing, some extra valves, and a tank. Good idea though, I'll give it that.
Old 09-08-2005, 06:43 AM   #10
gostranger
gostranger's Avatar
the system does not exaust out like normal systems each system has to be custom taylored for what you are running or you can blow op your compressor he cant explain it to to much detail he is negotiating with some air ride companies to sell the idea!!!
