Old 09-11-2005, 01:41 PM   #1
llegos
manual choke
I installed a new Q-jet on my truck and i dont think the choke is working right. when its cold, i have to keep my foot on the gas, otherwise it will die. what do i need to do to convert this to a manual choke?
is the choke even my problem here? i think it is since it seems to run fine when warm.
-Steve
llegos is offline   Reply With Quote
Old 09-11-2005, 04:18 PM   #2
neonlarry
neonlarry's Avatar
Haven't seen a manual choke conversion for a Q-Jet, why don't you just fix the choke you have?
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 09-11-2005, 10:29 PM   #3
llegos
cuz im not sure whats wrong with it.lol i just replaced the carb, so i think the vac actuator part is working fine. i read that to adjust that lil coil thingy, you are supposed to bend the rods or something, and i would probably just end up braking it if i tried.
reason i say this is that before the truck was idling fine, and i parked it, today i start it up, and the engine is cold, and it wants to die if i didnt rev it up myself. after it warmed up, it was fine.
-Steve
Old 09-11-2005, 11:12 PM   #4
jhow66
jhow66's Avatar
Check to see if the choke is closed before starting (cold). Start engine and see choke opens a small amount. If is ok to here set this screw(fast idle screw up until engine run with it in gear.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 09-12-2005, 05:54 AM   #5
'68OrangeSunshine
'68OrangeSunshine's Avatar
I think I got my manual choke conversion kit in the Help section at Checker Auto. I used it to convert a Carter 9635 to manual choke. Holley and Edelbrock both sell manual kits for their stuff. But that other one was a generic universal conversion kit.
Old 09-13-2005, 12:43 AM   #6
llegos
ill post a pic tomorrow, when i get the chance so you all know what i am talking about
-Steve
