09-12-2005, 09:32 AM | #1 |
Car 4 speed?
Ok, Dumb question of the day. Can a regular muncie or gm 4 speed from early camaro's, chevelle's, nova's, be made to fit in 2 wd trucks. Thinking about that with a 402 in my 72. Thanks.
Ps. modifying mounting brackets isn't a big deal for me, if needed. Also has it been done (I'm sure it has to have been with this bunch) and are there any pictures. Rivernut
'72 1/2 ton 350 auto |
09-12-2005, 10:06 AM | #2 |
Anything will fit if you use a big enough hammer.
The shifter will be in the middle of your bench seat. Got bucket seats? I'm sure someone makes a relocator for the linkage. That's why most truck manual transmissions are top loaders.
Silence is golden, duct tape is silver. - Scott |
09-12-2005, 10:10 AM | #3 |
Vintage Evil
I use to have a camaro 4 spd in the truck. It is not Heavy Duty enough to handle the weight. I went through 3 of them before i went back to a TH350.
It fit fine. Might have to adjust the length of the drive shaft.
Current Rides: Vintage Evil - 72 Chevy C10 (Always a work in progress) Vintage Evil Build Thread EvilK5 - 71 K5 Blazer Evil Twin - 2006 Suzuki M109R EvilDmax- 2018 GMC 2500 Denali Duramax |
09-12-2005, 03:35 PM | #4 |
Senior Moment
We have a Muncie M22 behind GM's 290 HP crate motor in my sons truck and its lots of fun. Using the Mr. Gasket Truck shifter, there’s no problem hitting the seat; however we do have the buddy buckets.
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 Last edited by 1970 CST Short Wide; 09-12-2005 at 03:36 PM. |
09-12-2005, 05:10 PM | #5 |
Any of th M20 (LARGE counter shaft shaft -...no..did not stutter - heavy duty has 1" counter shaft shaft), M21, or M22. Or...T10's will work. Avoid Saginaws...for anything with HP or torque...you will tear them up.
Hurst has a competition Plus shifter that works with a bench seat....with no problems. |
09-12-2005, 07:35 PM | #6 |
laying low
You'd be surprised how the Muncies just bolt right in. I put a Muncie close ratio 4 speed in my 78 Chevy truck that came from a 69 SS Nova. Bolted right in, input and output shafts were of the same size and spline counts as the stock truck 3 speed so the clutch and driveshaft yoke were correct. Tranny length was the same. I had mine swapped out in under 2 hours including cutting the hole in the floor for the shifter. Drove that one like that for 6 years.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross Last edited by Boog; 09-12-2005 at 07:37 PM. |
09-12-2005, 07:42 PM | #7 | |
senior member
Jason
69 GMC bagged |
09-12-2005, 10:13 PM | #8 |
Better late than never
Yes, avoid the Saginaw. I have had mine rebuilt twice and it has gone down again.
A buddy was just telling me that years ago he mounted a 3 speed overdrive tail housing to a 4 speed and made a 4 speed overdrive. I have not heard of that, but it sounds like a good deal. Anyone done that?
1970 C/10 SWB Stepside |
09-12-2005, 10:31 PM | #9 | |
blood type; Retumbo
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
09-12-2005, 10:38 PM | #10 | |
09-12-2005, 10:58 PM | #11 | |
senior member
Jason
69 GMC bagged |
09-12-2005, 11:09 PM | #12 |
They are around...just have to find a shop that specializes in manual transmissions.
gears4less? Something like that. Ask the companies that rebuild larger truck manual trans....they have the info. |
09-12-2005, 11:45 PM | #13 |
Saginaw overdrive conversion:
http://www.chevytrucks.org/tech/overdrive.htm A few hard parts, along with rebuild stuff & ID info can be found at http://www.dandltransmission.com/saginaw.html or you might find something at www.kajunjon.com Last edited by jimfulco; 09-12-2005 at 11:50 PM. |
09-13-2005, 12:11 AM | #14 |
Registered Cruiser
I've had good luck with my Saginaw four speed. Saginaw parts
I intend to live forever. So far, so good. |
