09-10-2005, 08:26 AM | #1 |
454 4 bolt main bare block
fresh from machine shop.needs final hone for sizing of pistons `you` decide to use.fresh .060 bore.comes with cam bearings/freeze plugs installed.this is a low deck,passenger car/light truck/motorhome block,NOT a high deck,2 ton truck,bus block,which are getting hard to find.e-mail only please at tmcgrawlookalike@hotmail.com.buyers responsibility for pick-up/shipping.i should be able to crate and deliver to shipping dock for you as long as you take care of any/all charges.in oklahoma city,oklahoma.550.00 FIRM-I ALSO HAVE A SRP PISTON/EAGLE CRANK/EAGLE I-BEAM OR H-BEAM KIT TO GO WITH THIS AT A HELL OF A PRICE.ASK ABOUT IT!!MARK
09-10-2005, 09:08 AM | #2 |
How much for the rotating assembly?
72 C10 longbed 5/7 drop, Telstars, 350/th400(for now) 69 Chevelle SS396 (427/th400) 88 K5 on 35's (355/700R4/208) |
09-11-2005, 11:30 AM | #3 |
well,lets see.i have a kit with 12.8/1(119cc o/c head)srp pistons(.060) or a kit with 10.3/1 srp pistons(.060)(119 o/c head),choice is yours.either kit with eagle i-beam rods,forged 4340 crank,h-series clevite bearings,file-fit sealed power plasma moly rings,sell at 1500.00.if you want the h-beam rods,and 100.00.you must final balance this assembly with your flywheel,balancer,etc.you will also be responsible for shipping.i also have 049,781,840,cast,aluminum,oval,rectangular,valve covers,gear drives.other than heads,this stuff is all new.
09-11-2005, 04:02 PM | #4 |
anyone?
09-11-2005, 04:26 PM | #5 |
How can you finish hone a block when the cam bearings and soft plugs are installed already?
Sorry....I have seen people try to do this before...and end up eating an engine. |
09-11-2005, 11:16 PM | #6 |
cam bearings NOT installed,but come with it.freeze plugs installed,but will not affect ANYTHING as far as final hone is concerned.sorry acloco,i did not specify but didn`t think i`d have to either.
09-11-2005, 11:18 PM | #7 |
Cool....I worked in a machine shop....the horror stories are like an emergency room.
09-12-2005, 02:36 AM | #8 |
You got mail....
71 GMC LWB 350, Dart Pro1's 200/64cc,10.2:1 RPM AirGap, 224/234 @50 496/518 lift w/1.6 roller rockers, 2500 stall '05 Dodge 2500 Crew Cab 4x4, 4 inch lift and 35's CTD |
09-13-2005, 08:15 PM | #9 |
anyone?
