Old 09-14-2005, 01:42 AM   #1
68_396Noel
Very Important Question!!!!!!
i have a 68 gmc 910 with all the options except a/c, it even has buckets. its all original and there is something i just noticed on the block when i was restoring it.......it came stock with a 396 4bbl, but this is where the question comes in, on the block it says that it is a 68 high performance 396... is this true?? do i have something here? could my truck be even more rare than i think it is?? can any one help me out. please.
68_396Noel is offline   Reply With Quote
Old 09-14-2005, 02:01 AM   #2
stllookn
Saving 1 truck at a time!
stllookn's Avatar
I have the same designation (PASS HIGH PERF OR HIGH PERF PASS) cast into the block behind the timing chain cover. This is an indication but not proof positive that the block had two additional drilled and tapped oil cooling holes and that it had 4-bolt mains.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 09-14-2005, 02:05 AM   #3
68_396Noel
what kind of horsepower does it have then?? is it the 375hp like the chevelle and the camaro??
Old 09-14-2005, 02:18 AM   #4
stllookn
stllookn's Avatar
310 hp Gross with 4-barrel and 275 hp Gross with the 2-barrel.
Old 09-14-2005, 02:27 AM   #5
68_396Noel
its bored .20 over as well and it has headers too.
Old 09-14-2005, 05:57 AM   #6
70GMCer
70GMCer's Avatar
All big block motors came with that Hi Perf name stamped on the rear on the block. Why Gm did this, I don't know......
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 09-14-2005, 07:45 AM   #7
Swbman
70GMCer is right, I recently got rid of 1975 model 454 car motor and it said hi performance passenger car stamped on the heads and it was nothing special about had oval port heads.
1961 BUICK LESABRE ** 1968 CHEVELLE SS 396 ** 1969 BUICK RIVIERA GS ** 1971 2 WHEEL DRIVE BLAZER ** 1971 4X4 BLAZER ** 1971 SHORTBED CHEYENNE FLEETSIDE ** 1971 SHORTBED 4X4 FLEETSIDE ** ...My Ebay
Swbman is offline   Reply With Quote
Old 09-14-2005, 12:03 PM   #8
chevyfarmer
chevyfarmer's Avatar
Backing up what everyone else has said. The 454 that I am building for my Blazer has the Hi Perf stamp on it, and I got super excited as well, only to find a 2 bolt main.
67 short wide 355ci 3 on tree
69 short wide 250ci 3 on tree
68 long wide 283 3 on tree
72 2wd Blazer project 454 5 speed
chevyfarmer is offline   Reply With Quote
