Old 08-20-2002, 02:06 PM   #1
Reumster
L.E.D. Freak
Reumster's Avatar
Question How too find Crank #s/what is it?
How would I find out what crank I have. I have these #s off the crank 3932442 /NF /6M70 /70 /F277 Them are all the #s that where on the crank. I need to find out what it came out of. I need to buy harmonic balancer. The one I have is the wrong one, TDC don't line up.
Specializing in Custom L.E.D. inserts.
http://www.ccled.com/
Contact me @ blazer2wd1972@hotmail.com
(406)675-8082
or Joel @ jmcwaters@eps-corp.net
1972 2wd Blazer, 350/700R4/3:73 posi, err & Custom L.E.D. inserts! LOL
Reumster is offline   Reply With Quote
Old 08-20-2002, 03:18 PM   #2
old_truck1969
old_truck1969's Avatar
This is what i found in the Catalog of V-8 Chevy casting numbers. 3932442 decodes to quite a few vehicles:
1 - '68-81 passenger car, camaro, chevelle or nova with a 350.
2 - '69-85 truck with a 350
3 - '76-85 truck with a 305
4 - '79-82 with a 267
All cranks with that code are cast iron and large journal
I think the rest are date codes when it was made.
"All Corvettes are red. The rest are mistakes." - John Heinricy
old_truck1969 is offline   Reply With Quote
Old 08-20-2002, 03:22 PM   #3
Blazer1970
Blazer1970's Avatar
3932442 is a '69 - '85 cast crankshaft used in 305s and 350s. I would think that is the same crank used in pretty much every two piece rear seal truck 350. There were two different positions used for the timing tabs on the cam covers. Older engines like what came in the '67 - '72 trucks had the tab at about the 2:00 position, and the later model ones had the tab straight up at 12:00. You just need to have the balancer to go with the tab position that you are using. The crankshaft is the same either way.
Blazer1970 is offline   Reply With Quote
Old 08-24-2002, 02:58 AM   #4
Reumster
L.E.D. Freak
Reumster's Avatar
Question OK
So if it came in a 305 and 350, a 305 and 350 have the same stroke? So I just need a blancer to match my timing chain cover?
(406)675-8082
