09-15-2005, 06:48 PM | #1 |
Professional Grade
Electric Fan placement opinions
Hey guys!
I'm setting my truck up with some electric fans, and I need some placement advice. Basically, I need to know which side I should be putting the big fan on, driver's side, or passenger's side. I am assuming that the hot coolant comes out of the top of the engine, into the rad and then is sucked back in the bottom side, so I'd figure that a guy would want to put the big fan on the driver's side where the inlet is, and put the little fan down by the pass side, where the coolant exits. Sound good? PS, the fans I am using are from two different chevy cars, one is from a 90s buick lesabre, with a 3.8, and the other is from what appears to be a mid 80s Nova. I think that chances are, I should be ok with just the big fan alone, as it is bigger, and has a steeper pitch to the blades than the stock fan was / had, but I want to put the little one on both for athetics, and for a backup if the big one fails for some reason. The little one is the same size as the 305 TPI Trans Am fans, and the big one is a little bit larger than the stock clutch fan. Both fans have their own mini-shroud, but I intend to install the stock fan shroud (if it'll still clear the TPI MAF ducting) both to protect fingers, and to provide my place to store tools again, lol Also would help with making sure that the air is directed properly at higher speeds, rather than just fluffing off wherever it wanted to go after it passed through the electric fan shroud.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
09-15-2005, 07:00 PM | #2 | |
Actually, I think it's the other way round.
*Andre* 1984 C10 SWB, 350/700R4 |
09-15-2005, 07:07 PM | #3 |
Professional Grade
I had the same nagging feeling, but then I remembered that the lower rad hose has a spring in it to keep it from collapsing from the suction of the water pump, so I am pretty sure it comes in the top, and out the bottom.
Could very well be wrong though!
09-15-2005, 07:13 PM | #4 | |
09-15-2005, 07:17 PM | #5 |
Yep,Russel, you're right. I just looked it up in my Haynes manual.
It's good you brought this up, cause I want to do the same mod as you this winter. So I suppose the biggest fan should be at the hottest spot, that's on the top left of the rad.
*Andre* 1984 C10 SWB, 350/700R4 Last edited by MidnightBlues; 09-15-2005 at 07:18 PM. |
09-15-2005, 07:22 PM | #6 | |
Professional Grade
I'm gonna mount the fan by the inlet, and see how it does there I just want to avoid making hot-spots the best I can.
09-15-2005, 08:42 PM | #7 |
Gentleman Jim Driver
The real answer to this is that it doesn't matter.
The area of the fan, the temperature of coolant and flow rates of both coolant and air are what determines how much heat will be rejected (cooled) by your radiator. If you place the fan on one side or the other, it will just stay hotter until it gets to where the fan is. Any gains by precise fan placement will be small.
Joe '75 GMC Gentleman Jim '84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter) '85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed |
09-15-2005, 08:50 PM | #8 |
Parts and more parts
The hot coolant goes to the radiator at the top of the motor (When the T/stat opens up). The principal is that heat goes up and cool goes down. So if you were to cool your motor off with natural circulation (what your motor does when it is turned off), then you would want the hot to go to the radiator at the top and go back into the motor at the bottom, to heat up again.
09-15-2005, 10:03 PM | #9 |
Professional Grade
Sounds good, I got them both installed I put the smaller of the two at the top of the rad so I could both make them look uniform until I get a full size shroud installed, and also to dissipate the rising heat.
I think they'll do just fine, I ran both fans at once, and they move a heck of a lot more air than the old mechanical fan used to! The big one definitely dims the lights and lowers the RPMs of the engine when it first turns on! Loud sucker, but I am pretty sure it'll do the job just fine!
09-15-2005, 10:41 PM | #10 |
you might consider this as a cheap, but very effective electric fan setup
http://www.fordmuscle.com/archives/2...an/index.shtml (i know, i'm using that "four letter word")
1987 350 TBI lowered 5/7 |
09-16-2005, 12:10 AM | #11 |
Professional Grade
I actually stopped by the wrecking yard today, with the intent of getting one of those fans. I pulled one off, and was a bit dissapointed in the coverage it provided, so I decided to go with a pair of GM fans instead.
The big one is off a 3.8 powered Buick Lesabre, and the little one is off a little mid 80s appearing Nova (had no idea GM made a Nova during the mid 80s! It reminds me a bit of the little Charger that Dodge made during the mid 80s). Between the both of them, the entire rad is covered less a spot about 4 " x 3" at the bottom pass side of the rad. I was actually quite impressed with how easy they were to install as well, the 3.8 fan almost bolted right in, only needing one tie at the bottom middle edge of the fan, while the Nova fan also bolted in at the top, with one tie at the bottom. The 3.8 fan was spaced perfectly to sit right on the rad, it also has little flat spots so the fan shroud doesn't rub, I stuck an old core support bushing between the Nova fan and the rad, so it wouldn't rub. After finishing the install, I don't believe I'll be able to install a factory fan shroud anymore, but thats not a big deal, cause this setup looks really good. My new TPI chip also arrived today, so tommorow it'll just be a matter of pulling the upper intake one last time to check a few injectors, and fix a vac leak between the runners and lower intake, put the upper intake back together, and find some way to connect my MAF to the airbox that I mounted on the pass side fender. However, I'm thinking I may just get myself one of those cone filters, and plop it on the end instead, cause that airbox looks pretty restrictive. We'll see how the truck performs with it. If all goes well, I should be able to pull the truck out of the shop under its own power tommorow After that, I need to replace the wiring harness for the front clip, the harness that goes to the box, install my divorced transfercase, get shocks and driveshafts, then buckle down and get the body work done. I am starting to see the light at the end of the tunnel!
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) Last edited by Russell; 09-16-2005 at 12:12 AM. |
09-16-2005, 12:31 AM | #12 | |
09-16-2005, 10:28 AM | #13 |
You get what you pay for
Russel,
you said you were going to install a shroud. You don't need one. The way you have your fans installed is the best way of doing it. Right up against the radiator. I have two Spal fans installed the same way. A shroud will only impead air flow when the fans are not running, as in normal driving conditions. A nicely built shroud looks very cool but is a total waste of time and money, IMO.
Mike 1985 Chevy C-10 |
09-16-2005, 11:19 AM | #14 |
Professional Grade
Ok, sounds good, I was thinking it'd help flow when a guy was going down the highway, but I couldn't think of how I was gonna mount it, seeing as my electric fans took the original shroud mount, lol
I guess we'll find out tonight if the big fan is up to keeping the small block cool
09-16-2005, 02:37 PM | #15 |
Do you have them hooked to a temp switch so they only come on when needed or wired to stay on all the time? You really need the switch because you won't believe how much they are not needed. In the winter, mine never come on, anytime. In the summer, they will only come on if it's real hot and I get at a stop for awhile. Even then, in the summer they never come on in normal driving.
Good luck with them. Mike |
09-16-2005, 05:03 PM | #16 |
Professional Grade
I've got the big one wired to my TPI ECM, and the little one is on a temp switch in the head of the engine and a manual switch by my towing brake controller. I mounted my tranny cooler right behind the small fan, so I would like to have the ability to turn that little fan on, and have it running at all times when I am towing a trailer to keep tranny temps down. When I am not towing, it'd just be there to act as a complimentary fan to the big one if it is not able to keep up on a 100 degree day stuck in traffic
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) Last edited by Russell; 09-16-2005 at 05:11 PM. |
09-16-2005, 05:45 PM | #17 |
Your install looks real good. Do you happen to know the diameter of those fans? I also like the way you wired them up. But I am curious what thermostat temp you plan to run, what temp does your TPI ECM turn the big fan on, and what temp your thermal switch turns the small fan on? Oh, and do you have a temp gauge in the transmission pan?
- Greg |
09-16-2005, 11:18 PM | #18 |
Professional Grade
The big fan is a 16" fan, and the little one is a 12" fan. The thermostat is a 195 F unit, right about where the TPI likes to run. The ECM is programmed to turn the fans on at 205 F, and off at 185 F, if I remember correctly. The little thermal switch is suppost to turn the fans on at 220 F, and off at 185. I currently don't have a tranny temp switch, though I think I probally will install one sooner than later. Just need to find a nice place to put one
