![]() Join Date: Jan 2001
Wanted: 71-2 3/4 ton front brake parts
Hi all,
I figured I would give this a try as a wanted thead as I have had no luck trying to find a set close to me. I need the 8 lug disk setup (w/ spindles would be the best bet) off of a 3/4 ton 71-72 truck. I am switching to diesel and a hydroboost so disks in the front are the way to go. Please let me know if you have these somewhere reasonably close (shipping wise, or I can pick up) to North Carolina. Thanks in advance, Orlando |
![]() Join Date: Jan 2005
I have some, but probably too far
68 Short Stepside C-10 69 SWB C-10 70 Flatbed C-20 70 LWB C-20 BB402 70 LWB C-10 CST 70 LWB C-10 CST 71 Short Stepside Cheyenne C-10 72 LWB C-10 72 Blazer 4x4 4spd 95 Jeep Cherokee 4x4 |
![]() Join Date: Jun 2003
I have a pair of spindles off my 71 K20 that could use some cleaning up. Still very good condition on the bearing surfaces. Will sell them for $40.00 plus shipping from PA.
72longbed |
bump...
72, thanks but I was wanting the whole thing spindles out, not just spindles. Orlando |
huh ???
2wd or 4x4? Sounds like the ones that 72longbed has are for a 4x4...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
forgot
Good point. This is a 2wd rig.
Orlando |
I just wanted to let you know that you can use 3/4 ton parts from 71 to 87. I just got a complete front crossmember with all suspension,steering and brakes from an 83 c-20 and it bolted in my 69 c-20.I only had to drill 2 holes on each side.
I've got a pair of spindles with rotors from a 71. $50 but far away from you.
