![]() Join Date: May 2005
installing a 90s truck 5 speed in a 67-72?
i'm planning on installing a 90 truck manual 5 speed in my truck and was wondering if there's anything i should be aware of before i get started. i know a couple people have already done this. what fly wheel, cluth, and pressure plate should i use, the 72 or the 90 setup? is there any problem because the 72 engines have a two rear main seal and the 90 has a one piece? i know the 90 tranny has a electric speedo, can i change it to a mechanical? do you use a automatic croosmember? do i need to drill new holes in the frame for the tranny crossmember? what tranny mount do you use? i was thinking of using the 90 hydralic clutch, any reason i shouldn't? what pilot bearing? what throwout bearing? low or high hump cab? any help would be greatly appreciated! thanks jake
67 short fleet 71 blazer 4x4 72 blazer 2wd 76 gmc sierra 3/4t 4x4 62 bel air 01 blazer extreme member 11,943! |
#2 | |||
Union Electrician
I know Huck has done this or had a truck like this with a newer 5 speed in it. I suggest you PM him and ask...Randy
![]() ![]() Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
