Old 12-04-2004, 06:56 AM   #51
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Check the dealer for Vortecs...If I remember correctly, they should be just over 400 bucks.
Old 12-04-2004, 07:51 AM   #52
That 400 block alone is work good money by itself.But,if crank turns out useable,why seperate.400s are getting hard to find.A 383 job on a 350 block is slick.But,a 400 already has the torque.And,they can be built to 406 or even 426.Now that`s a B/A small block!Those saddle tanks are add-ons.Often by dealers,mostly in the westsrn states.It`s gonna be tough to find a trade on that TH350 for an 700R4.You might try a junkyard or buying a donor vehicle.By the time you have that rebuilt,you might wanna weigh the option of an outright unit fom someone like Jet Performane.I knlw,we`re gettin` pricey.Good luck,nice trucks.
Old 12-04-2004, 01:30 PM   #53
Jakes-66-K10
Jakes-66-K10's Avatar
Thanks. Just to clarify, I am keeping this a 400. It turns out my crank was still perfectly fine even after throwing a rod. My previous 400 block was going to need a sleeve as well as getting bored over again. Luckily I found a virgin 400 block that has never been bored, and cost just a little more than a sleeve repair would have been. So yeah, this will probably turn out to be a little shy of a 406 small block (only going .20 over so I can rebuild again if needed) with 5.7 rods and vortec heads - at least that is the plan so far. Should be fun!
Jakes-66-K10 is offline   Reply With Quote
Old 09-19-2005, 01:43 PM   #54
Jakes-66-K10
It's been along time since I've given an update to this truck. Here are some pics of progress I've made. Nothing costmetic has changed to the exterior. But at least it runs strong and is back on the road!
Instead of the small block 400, I opted to put that into another truck and put a new GM Goodwrench 350 in this. Installed a 700r4 behind it that I got from bisquick65. What a great feeling to have it drop into fourth gear!
Also installed new carpet, a tach dash, driveline, exhaust, power brake booster, etc. Just little things here and there when I get time, and money. Next up is the disc front end conversion.
Many, many thanks to all those who have chipped in with answers to all my questions. This truck simply would not be here if it wasn't for this board!
Old 09-19-2005, 01:52 PM   #55
panhandler62
Java Mechanic
panhandler62's Avatar
2 projects eh, that Bug doesn't look like much of a project
He could put an LS1 in the Bug.. that might be interesting... LOL
Nice truck there.. I see I'm not the only one with er.. "alternative" materials making up my cab corners. )
I love the 66. Is that the one that was giving you fits when you first got it running?
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
Old 09-19-2005, 01:55 PM   #56
Jakes-66-K10
No, it was this truck pictured, the '70. You have a good memory. What it boiled down to was having the incorrect harmonic balancer, so my timing was not where it needed to be. And replacing my Road Demon carb for this Edelbrock. Runs great now!
Old 09-19-2005, 02:48 PM   #57
Lemield
Lemield's Avatar
Originally Posted by vortexofpain
Here are some of the things the truck came with that are a little unique. It has two saddles tanks on each side of the bed, sure looks to have come stock but I could be wrong. Also, it came missing it's tailgate but inplace had a rail/gear system to hoist a camper onto the bed.
Hey Vortexofpain,
The camper loading gizmo is called an EZloader. I have on for my 1969 Mitchell camper that came with my 1970 C20 Custom Camper. They work really nice for loading the campers....just walks them right up into the bed.
It's a strange coincidence that I have a green truck and a Silver Beetle too.
Larry
1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green"
1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red"
1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon"
2005 VW Beetle Diesel 44+ MPG "Silver Bullet"
Lemield is offline   Reply With Quote
Old 09-19-2005, 04:26 PM   #58
chickenwing
Lovin' Life in Miss.!
chickenwing's Avatar
Super nice truck! I especially like how everything you have touched, you have cleaned. Damn thats a lot of work! See you have the BTO TV set-up. Made that 700 install easy, huh? Only 2 things I'd like to point out to save ya some trouble later is to put some heat sleeves on your plug wires if u are gonna route em like that and ya might wana think about getting a double spring set-up for your carb return. Would kinda suck if that one broke. Hope ya don;t leave us hanging for another 9 months!
Rich
chickenwing is offline   Reply With Quote
Old 09-19-2005, 06:44 PM   #59
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Thats turning into a really nice ride.. Keep up the good work..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 09-19-2005, 07:37 PM   #60
Canadian694x4
Born To Lose Club
Canadian694x4's Avatar
Location: Calgary, Alberta/Oxenden, Ontario, Great White North
Great Work! Keep The Progress Pics A Comin'
Brian Smith - "Born To Lose"
1969 Chevrolet K10 LWB Fleetside - Proud Owner For 22 Yrs - 1 of 208 Built & Sold In Canada!- 283 V8/350TH/NP208, 2" All Spring Lift, 32" Good Year MT/R's.
1972 GMC K2500 Custom LWB Fleetside - Proud Owner For 3 Yrs - 1 of 571 Built & Sold In Canada! - 350 V8/SM465/NP205, 4” Rough Country Lift, 33” Interco TSL Thornbirds
2007.5 GMC Sierra SLE 2500HD 4x4 - Proud Owner For 17 Yrs- 6.6L V8 Duramax Diesel/Allison 1000, 2" Lift, 33" Mickey Thompson MTZ's.
2008 Yamaha Raptor 700r - Proud Owner For 15 Yrs - ITP Mud Lites.
2015 John Deere 1025R - Proud Owner For 8 Yrs - 24HP Diesel/H120/54D/260B/SB1154.
Canadian694x4 is offline   Reply With Quote
