Old 09-18-2005, 11:51 AM   #1
dennislbrooks
dennislbrooks's Avatar
66C10 Power Steering
What later model power sterring gear will bolt up to a 66 column shaft? Or how did you complete this task?
thanks
dennislbrooks is offline   Reply With Quote
Old 09-18-2005, 08:29 PM   #2
zenish
none will bolt up. you can use the "rez"conversion kit to use a 71-87 power steering box.it requires minor welding.
1964 c10 short step
1962 econoline van
1989 rs camaro
2006 yamaha vino 125
1975 goldwing
zenish is offline   Reply With Quote
Old 09-19-2005, 01:03 AM   #3
Mongo
YES_____NO
Mongo's Avatar
Brothers sells a kit that requires no welding, just have to drill one extra hold in the frame
Power sterrung Adapter kit
People many not remember what you said or what you did, but they will remember the way you made them feel. - unknown
Cause, remember: no matter where you go... there you are. - Buckaroo Banzai 1984
Help support the board
Mongo is offline   Reply With Quote
Old 09-19-2005, 08:42 AM   #4
dallas71
dallas71's Avatar
I believe the welding zenish was reffering to is when you cut the steering column rod....due to the power steering box being longer than the manual box...
dallas71 is offline   Reply With Quote
Old 09-19-2005, 10:00 AM   #5
Jakes-66-K10
Jakes-66-K10's Avatar
I believe that Brothers kit and the Rez Engineering are the same thing. Check out www.americanclassic.com, I remember seeing they have pre-made column shafts the right length, so you don't have to cut up yours if you aren't experienced at welding.
Jakes-66-K10 is offline   Reply With Quote
Old 09-19-2005, 02:11 PM   #6
chevy283
chevy283's Avatar
or u can swap steering columns i got a 91 sub column in mine no welding.
65 c10 tore apart
70 c10 305/350th
chevy283 is offline   Reply With Quote
Old 09-19-2005, 08:22 PM   #7
dennislbrooks
chevy283 --got any pics----thanks
Old 09-19-2005, 10:42 PM   #8
mbgmike
I never welded anything. I put on the rez eng kit with a mid 85's box and used a stock intermediate shaft (the collapsible type) new rag joint. 68 tilt column
mbgmike is offline   Reply With Quote
Old 09-20-2005, 06:18 PM   #9
chevy283
chevy283's Avatar
no it looks cool though. Check out this site he used a 80s sub colume. http://geocities.com/vapershing/pickup.html
65 c10 tore apart
70 c10 305/350th
