cd changer question
Will a cd changer fit in that passenger side space behind the seat?
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
only if you remove the tank.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
should fit under seat ok then I imagine.
if you have a stock bench it should be fine under a seat.
'68 C-20 396 CST CC
![]() Join Date: Mar 2005
I have a ten-disc Sony and it fits in the jack space (passenger-side cab corner) just fine in the vertical position. I'm building a bracket that will bolt into place where the jack retaining clip and spring are mounted to hold the changer level. Right now it is just sitting in a nest of clean rags and there is plenty of room.
68 C-20 396/TH400 CST Custom Camper NOW W/DISC BRAKES ![]() 01 Jetta Turbo Daily Driver ![]() 84 Yamaha Virago 700 - Alaska to Florida Via Maine & Mexico ![]() Last edited by thecatseye66; 09-20-2005 at 11:41 AM. |
does it work not bolted in like that?
'68 C-20 396 CST CC
Yeah, and I was surprised too.
I wired it when I put in my carpet and insulation and then I made a stable little nest of rags to keep it from bouncing around just to see if that is where I would want to mount it permanently. Everything works really well, no skips and all I have to do is pull the seat forward and push the "release" button and the CD cartridge ejects straight up toward the roof. On Sunday I took out the rags and made some measurements for a bracket I need to build to hold it in place. I'm thinking I'll mount a bracket to the two holes in the floor that hold the little jack bracket, but if it isn't secure enough I can weld a brace on the bracket that will extend to the back of the door where the large phillips-head screw holds the large jack spring behind the door.
68 C-20 396/TH400 CST Custom Camper NOW W/DISC BRAKES ![]() 01 Jetta Turbo Daily Driver ![]() 84 Yamaha Virago 700 - Alaska to Florida Via Maine & Mexico ![]() |
How about mine in the glove box mounted on a bracket?
If it don't fit, force it,...If it still don't fit , modify it 'till it does fit !!! ![]() ![]() |
