09-20-2005, 07:12 PM | #1 |
need v8 clutch linkage
i have a 68 gmc and am swaping the stright 6 for a v8 and need clutch linkage the truck had a 3 spd and i am putting a 5 speed but the 6 cly linkage mounts off the block and i need linkage for a v8 i only need everything outside the fire wall
09-20-2005, 10:10 PM | #2 |
linkage
I have it. If you want some pics, pm me your email address.
09-21-2005, 05:55 AM | #3 |
I did the same swap in a 1969 K20, all I did was remove the bracket that bolts to the 6 cyl via two bolts. The pivot ball stud then scews directly into the V-8. The bracket just makes up for the difference in engine width.
1969 K20 Custom |
