Old 08-25-2002, 05:46 PM   #1
Question Brake Lines
I just redid my drums and am planning on putting a power booster unit on it. I have replaced all cylinder and hose for the wheels, but I am thinking of replacing the lines when I hook up the booster. Alsthough they are not leaking, I think I would feel more comforatable with new lines.
I noticed the Cevh Duty, maybe some others have premade lines from the brakes. I don'e have any bending or flaring tools at the moment and was wondering has any one used these premade lines or do you make your own.
I'm not sure what the cost difference would be. Not even sure what tools/sizes I would need if I were to do my own.
Suggestion/recommendations appreciated.
Old 08-25-2002, 05:54 PM   #2
Tim Christian
Tim Christian's Avatar
Smile
I used the ones from Inline Tube. You can order from them direct. This is the same place Chevy Duty buys theirs from. They just drop ship them.
Tim Christian is offline   Reply With Quote
Old 08-25-2002, 05:56 PM   #3
hjalbert
cracker
hjalbert's Avatar
I got mine from inline tube also, got the stainless, they were very helpful, and i like the lines,
FOUNDING MEMBER OF THE DRUM BRAKE CLUB
Harry John Albert III
located in Phoenix, AZ
1972 GMC JIMMY,
1969 lwb Chevy Frame,
1999 bmw k1200 ltc
1992 Kawasaki concours
1991 bmw k75
1973 cortez motorhome
hjalbert is offline   Reply With Quote
Old 08-25-2002, 07:17 PM   #4
Question
Oh yeah...Forgot to ask this with the first post...Looks like the front and rear axle aren't going to be a big problem, but my Chevy is still assembeled...How bad is it to run the lines with cab and bed still in place?
Old 08-25-2002, 07:28 PM   #5
Hooter
My other Love
Hooter's Avatar
It can be done, but like with anything automotive related it can become frusterating
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 08-25-2002, 08:18 PM   #6
I hear that...Only thing that challenges us more is teenage girls (if they are yours)!!
Old 08-26-2002, 04:17 AM   #7
seventy-3QT-K5
My 2 cents is that if you do build your own, make sure you spend the money for a good flaring kit. I had some taiwanese crapola set that wasn't strong enough to double flare. What a nightmare. I also ran my frame brake lines while my body was on. Be patient is the best advice. Lucky for me I had a lift on my ride so I could get under it easy!
seventy-3QT-K5 is offline   Reply With Quote
Old 08-26-2002, 12:40 PM   #8
kxmotox247
kxmotox247's Avatar
When we do street rod brakes, we use 3/16" brake tubing. When I start on my 68', I'll definately run my own lines.
I think pre-bent ones would be the easiest for when you have your sheet metal in place though.
As far as doing your own lines and making your own double flares...we stopped making our own double flares and started joining the lines together using compression fittings. These are available at your local hardware store.
Where I work, our hydraulics man seems to believe a brake line joint using compression fittings is more than adequate for handling the pressure.
I have had no leaks at all in the 2 cars I have done using compression fittings.
Of course this is all just my opinion but it might save some money and double-flaring is a pain.
kxmotox247 is offline   Reply With Quote
