09-16-2005, 01:37 AM | #1 |
Transfer case mounts?
LMC is the only place I have been able to find mounts for the transfer case. Is there any other place out there? I am also looking for good replacement engine mounts but anytime you say 4WD, they look at you funny. Why does no one carry hardly anything for the 4WD? I still have to check my local autoparts store but I find odd that so few mail orders companies carry the 4wd stuff.
Mike
Mike Redpath |
09-16-2005, 10:28 AM | #2 |
Junior Member
i found both the upper and lower tcase mounts at our local napa store. the only mount that i could not find is that one on the side of the tcase, it is a round bushing that fits into a small plate that bolts to the frame.
hope that helps! |
09-16-2005, 01:00 PM | #3 |
Energy suspension makes them in poly. I believe some of the vendors on this board carry them.
Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 Last edited by CUSTOM/10; 09-16-2005 at 01:00 PM. |
09-16-2005, 01:11 PM | #4 |
SKINNY TIRES RULE!
I put in the Energy Suspension poly mounts in my '69. They were a lot less expensive than the original rubber ones. I've heard they can transfer more vibrations from the t-case/transmission than the rubber ones, but in my lifted '69 with a build engine, it just doesn't matter. I got them from http://www.4wheelparts.com/ (at the actual store though).
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
09-16-2005, 03:07 PM | #5 |
Back in the sticks
My engine mounts were the same for 2 or 4wd. Except for one having a metric bolt pattern for the engine bolt Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
09-16-2005, 06:08 PM | #6 |
Well I have tried O'Reilly's, NAPA, Classic Chevy here in OKC, with no luck. I guess I will go to plan "B" and order them. I was kinda hoping to get the LT-1 and 700R4/NP205 mocked up this weekend.
Mike
Mike Redpath |
09-17-2005, 02:08 PM | #7 |
Junior Member
i could get you the napa part # if interested. i just bought them there 2 weeks ago. very resonable price too!
09-18-2005, 01:28 AM | #8 |
That would be great thanks. DO they come with the center bushing as well. I need them too. LMC has the poly kit with bushings for $25 if I decide to order them.
Mike
Mike Redpath |
09-18-2005, 02:13 PM | #9 |
Junior Member
i bought motor mounts and tcase mounts all in the same day, so my reciept has three different part numbers on it and i dont know which is which. these are the napa part numbers-
602-1034-$12.78-should be the upper t-case mount 602-1035-$9.78-should be the lower t-case mount 602-1108-$14.78- i am pretty sure these are the motor mounts under the "line" column on the reciept they all say "BK", they may want that too. each of these prices is for 2 each. it comes with what they call upper and lower mounts. that is the big u shaped mounts for on top of the crossmember, and the smaller square mounts that go on the bottom of the crossmember. then your bolts go up thru both mounts into the tcase. i believe that is what your looking for. if they want, they could call the napa here- 605-578-3552. hope that helps mike |
09-18-2005, 05:13 PM | #10 |
Nope, not the ones I am after. Those had already been changed. I need the side support mounts that attach to the right side of the frame. There is 4 of them with a spacer.
Mike
Mike Redpath |
09-19-2005, 02:16 PM | #11 |
Junior Member
yes i need the same ones. napa did not have those. let me know what you find.
09-19-2005, 03:33 PM | #12 |
I just ordered them from LMC, poly only with bushings for $19.95 + shipping. They said up to 2 days to ship? and 4-6 days from KS to OK? WTF? Most places I have dealt with ship same day or next. In theory I should have them by Wednesday. This is my first order with them so we will see. I wish I could drive up the street to Classic Chevrolet Parts in OKC and pick them up but they don't carry them. So it is costing me an extra $8 to ship and several days wait. AAARRRGGGHHH!!!
Mike
Mike Redpath |
09-19-2005, 05:59 PM | #13 |
Junior Member
thanks for the info
09-24-2005, 11:49 AM | #14 |
PROJECT 7DEUCE
Let us know how it turns out as I als o need those side mounts..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
09-24-2005, 12:31 PM | #15 |
Well I got them on Friday after ordering them Monday. They are made by Prothane, Prothane p/n 7-1603-BL. The inner bushing is 9/16 ID and the bolt is 1/2, so it looks like I will be making a sleeve. There is a thick bushing and a thin one. Not sure which way they go yet, but other than making a sleeve, everything looks like it will bolt up fine.
Mike
Mike Redpath |
