Not a bad nut after all..
'71 w/Intermittent Electrical Power Problem
I have a '71 K5 Blazer with the original points ignition. Sometimes it acts as though there is an open circuit from the battery somewhere (no headlights, no courtesy lights, won't crank). The battery and its connections are good. I replaced the ignition switch thinking this was the problem. When it is dead I can't revive it, but if I come back another day sometimes it is okay.
What else should I look at? I'm beginning to think it is possessed... Wes Last edited by badpeanut; 08-24-2002 at 08:43 PM. |
Formerly yellow72custom
I have had the same problem on my '72 before. Once, i was driving along after dark, on a moonless night, and the whole truck just died. Motor stopped, no lights worked, nothing electric. I had to feel around and find my flashlight. Turned out that the wire that goes off the + battery cable, the 10ga lead, had fallen out of its connecter. The connecter was the little black box (about 1"x1") that is mounted on the passenger side fender, next to the battery. If you loose a connection there, everything will go dead because all the power in the truck goes through that point. I would check all the connections on that wire, and trace it all the way up to the alternator. Also, check for a bad ground somewhere. Bad grounds have been known to do some pretty weird stuff.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
I know you said the bat connections are good but if by chance you are using the after-market replacement cable ends that clamp onto your old cable many times folks don't think to check and clean both ends of that clamp, the bat end and cable end.
1971 C10 swb stepside 350/700R4/3.73posi (retired as of 4/22/03) 1998 S10 short bed 2002 S10 Blazer 1942 Oldsmobile 1958 Massey Harris Pony 1951 Wife Killingworth, Connecticut May those who love us, love us, any of those who do not love us, may God turn their hearts. And if God is unable to turn their hearts, may he turn their ankles so we may know them by their limping. A man who works with his hands is a laborer; a man who works with his hands and his brain is a craftsman; but a man who works with his hands and his brain and his heart is an artist. |
![]() Join Date: Jul 2002
I've seen corrosion in a fuse panel cause an intermitant problem with all of the electrical. It also was causing some fuses to blow as well.....?????
Patch |
Check and clean all grounds!!!!
Car Knocker
I agree with everybody. I've had the same problem as you and it was the terminal end on the passenger fender. I finally just bypassed it and installed a 50 amp fuse sodered in its place. Also having problems now with the fusebox corrosion. Had drivers door off for a couple of months while doing body repair and have been fighting the fuse box ever since. Truck was outside. My shop is my driveway. NO work when it rains.
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit. |
Sounds like you have a bad ground. I would check the gound wire that attaches to the block. Take it off and check the wire and clean the block where the wire attaches. There should be another wire that comes off the ground terminal of the battery and attaches to the body. I would check that and clean where it attaches. Need to make sure you have a good metal to metal connection. You might have another wire coming off the block and attaches to the frame. I just check my 72 chevy and it looks like I don't have a wire from the block to the frame. Hope this helps.
Bob Hinz |
Thanks everyone! It turned out to be the black terminal box on the passenger fender. I cleaned the connections, greased them, and added an externally toothed lock washer.
Wes S. |
I am a Referee of life.
Glad you found it.I had one more suggestion to add.I had a car in HS that would take a notion to not crank or anything once in a while.I spent months looking for the problem and replacing parts.I finally found that by using a jumper cable from the battery to the starter it would start.The cable had corroded inside the insulation and would make contact or not sometimes affected by the temp.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
'Heavy Metal' Redefined.
Lots of good advice here. I've fought many similar battles a while ago but most of mine involved finding a short that would drain the battery (finally found it in the steering column).
One question: What does the black terminal box on the passenger fender do? It's been so long since I bypassed it that I forgot where it hooked to and what it did. Thanks, Mike
1967 C10 LWB stepside, 250 engine, GM HEI, aftermarket A/C., Clifford Performance intake, Stovebolt split headers, Carter AFB 500, X-pipe & Dynomax Super Turbos, 1 piece custom driveshaft, cyprus bed wood & stainless bed strips. Starkville, Mississippi | My Truck Page |
Someone can correct me if I'm wrong, but the black terminal box just looks like a convenient way to tie the power lead from the battery into the rest of the truck's harness.
My other Love
I remember when the wire came off the little box, while i was driving it came off, when it came off the voltage regulator suddenly didnt have any power going to it which caused a big voltage spkie in my electrical system, burned out quite a few lights and ruined my tach. now i learned to use fuses.
![]() Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
