Old 09-11-2005, 04:25 AM   #1
gregbr
Senoir Member
gregbr's Avatar
Need xfer case length measurements
Can somebody tell me the overall length of a np205 & np208. I'm comparing to my 203 the PO put in my 67 K10. Greg
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4"
70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010
70 GMC Restoration Pictures
http://67-72chevytrucks.com/gallery/...00&ppuser=4424
gregbr is offline   Reply With Quote
Old 09-24-2005, 06:04 AM   #2
gregbr
Senoir Member
gregbr's Avatar
ttt
Old 09-24-2005, 01:11 PM   #3
Americanrider
I have 2 NP 205's one auto and one 4 spd setup, are you looking for total with adaptors or without?
Americanrider is offline   Reply With Quote
Old 09-24-2005, 04:32 PM   #4
gregbr
Senoir Member
gregbr's Avatar
Transfer case without adaptors would be good. Thanks.
Old 09-24-2005, 10:09 PM   #5
jec
jec's Avatar
American Rider - I would like to know overall length of automatic TH400/adaptor/NP205. I am considering swapping out my SM465 set-up.
jec is offline   Reply With Quote
Old 09-25-2005, 08:46 AM   #6
gator2511
gator2511's Avatar
TH400 is 24 3/4" Adapter is 4" and the np205 is 12" to 13" from the front of the case to the center of the output yoke. Total would be about 40 3/4" to 41 3/4". I'm down in the back right now or I would crawl under the truck and measure mine as it sits under the truck. At least this will give you an idea of how long this combo is. The adapter should include a new input gear for the transfer case with a 32 spline input to match the th400 tranny.(machine shop work). You need to use the 2wd version of the th400 with the short tailshaft.
gator2511 is offline   Reply With Quote
Old 09-25-2005, 01:24 PM   #7
Americanrider
the 4sp 205 I have is 13 inches, the TH350/205 is 12 inches. The difference being the type of rear yoke that is installed.
