Old 09-24-2005, 08:29 AM   #1
Paul72
Paul72's Avatar
PICS WANTED - 3/4T w/33's
I would like to put 33x12.50's on the K/20 (stock ride height) and would like to see pics of this combo. Also any rubbing/interference problems? The wheels are 16x8 (don't flame me for this - I know 10" wheels would be better).
My gut feel is that this would be no problem, but want to double check before I spend the $$
Thanks,
Paul
'72 Chevy K20 - 383/4sp/205 - SOLD after 41 years in the family
Next project - K/5 Tahoe (71 Blazer on 99 Tahoe chassis) Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=789958
Paul72 is offline   Reply With Quote
Old 09-24-2005, 09:49 AM   #2
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Looks great...my roommate used to run them on his '72 and here they are on my '68 with the stock 8.25x16.5 rims. Plenty of clearance. The rears are 33x12.5x16.5 and the fronts are 31x10.5x16.5's but the 33's will fit on the front and I will change them once the 31's wear out.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 09-24-2005, 11:05 AM   #3
Jakes-66-K10
Jakes-66-K10's Avatar
Here are pics of my '67 with 33's on a 16.5 rim before and after I bought it.
Jakes-66-K10 is offline   Reply With Quote
Old 09-24-2005, 12:00 PM   #4
Paul72
Paul72's Avatar
Thanks for the pics! Forgot to mention mine is a 4x4.
Paul
Old 09-24-2005, 01:00 PM   #5
Stocker
20' Daredevil (Ret)
Stocker's Avatar
If you have any interference at all, it will be at the lower front corner of the fender (in front of the tires) - typically only with the wheel turned out, off-road, with the suspension compressed at that corner. If you don't mind a little hacksaw trimming, it's easily fixed and barely noticable. Chances are with 8" rims instead of 10", you won't have any problems at all. I'd say go for it - that's a great size for a K20, you won't regret it.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 09-25-2005, 02:37 AM   #6
4x4Poet
8" rims are always better than 10" rims when using 12.50 radials. Better bead seating; better sidewall buldge; better road manners since, with an 8" rim, the sidewall won't so easily flex inside the bead plane under hard cornering. About the only instance 10" rims would be better would be flotation for sand travel.
I've used 12.50 tires for two decades now and have always used 8" to 8.5" rims.
As for fender clearance with 33s on stock K20 springs, the main area of concern is the bottom of the front fenders next to the bumper. The front fender "cup", as it's often called here. A little trimming there solves any rubbing issues for most wheelers. Maybe not for extreme wheelers, but they run lift springs anyway.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 09-26-2005, 03:44 AM   #7
al's71gmc
4 eyed fever
al's71gmc's Avatar
I have 8" rims with 33 12.50 16's on mine, but went with a 4" lift. When turning they were too close for my liking. I don't consider myself to be an extreme wheeler by a long shot. I've got a bolt head sticking out behind the tire on the fender well and it was rubbed clean and shiny without even going wheelin. The front also had rub marks. But it doesn't take much of a bump for your tires to rub when you're turning. I guess it just depends on your driving habits and preferances. I also like the stance a bit more with the lift.
Al
1971 GMC 2500 4x4
1972 GMC Sierra Grande 1/2 t 4x4-#1 son's truck. Recently completed resto.
4 YO daughter," Daddy, I like your truck better than Mom's." (2000 F350-ranch truck) Smart kid!!
al's71gmc is offline   Reply With Quote
Old 09-26-2005, 10:31 PM   #8
1STtimePRo'71
1STtimePRo'71's Avatar
33x12.5x16.5's
-Cory
1967 2 Wheel Chevy
1STtimePRo'71 is offline   Reply With Quote
Old 10-03-2005, 10:28 PM   #9
Blue_71
Bloo
Blue_71's Avatar
here is a pic of mine--- on the left is with bald 31/10.5s on 7 inch wide wheels, the right is 33/12.5s on the same 7 inch rims
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 10-04-2005, 09:20 AM   #10
The white one has 33/75x16.5 0n 9.75 rims.The springs are very negative arched.
The 2-tone has 285/75x16s on 8 rims.It has an added leaf and they are straight.The 33s are a good bit shorter than the 285s.They both rub a bit,fit good enough for street.
