Old 08-26-2002, 01:05 PM   #2
ThreeQuarter
ThreeQuarter's Avatar
What exactly are you looking for? (What is "improved"?) Are the brakes too hard or too soft? Or is it the 1/2 mile of pedal travel before you actually start braking that is bothering you? Unfortunatley GM has designed them that way, but some trucks are not as bad as others.
If they're all the same part numbers then it probably won't. Might call a parts store and ask for price on a booster and M/C for an '88, then ask if that's the same part number for '96-ish. If they're not then you might see good results. Of course they might not be compatible, too. I don't know if 4-wheel ABS that was available on later models would affect this.
Also, I know the ext. cabs got bigger brakes (at least in the earlier years) so that might matter if you're swapping from reg. cab into an ext. cab.
I wanna hear how this turns out.
Ben
Ben
'68 Chevy C10 Custom LWB 327/TH400 2nd owner
'94 Ford Explorer XLT 4wd
'25 RAM 1500 Laramie 4wd
ThreeQuarter is offline   Reply With Quote
