Old 08-26-2002, 12:57 AM   #1
Low68
Low68's Avatar
brakes locking up?
Hey my room mate is having problems with his brakes. He took it to a shop and they wanted two hundred and fifty bucks to fix it. They said that the brakes are starting to lock up. What could be causing this? I was going to go out tomorrow and look at it and maybe test drive it. Any ideas are really appreciated. It is a crx(the universal college car that half the students in america drive). Thanks
Low68
Build Thread
Low68 is offline   Reply With Quote
Old 08-26-2002, 02:36 AM   #2
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
bad pads can do that, so can warped rotors.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 08-26-2002, 03:06 AM   #3
colohusker
I'd bet on the warped rotors. My corrolla was doing that with one wheel and that's what it was.
Scott
I say it's only money, my wife says it's only a truck....
'71 C10 Deluxe, factory ac, ps, pb, should be done by 2102
Longmont, CO
husker95@hotmail.com
colohusker is offline   Reply With Quote
Old 08-26-2002, 02:19 PM   #4
Project1970
14.1 @ 96MPH
Project1970's Avatar
Which wheel/s is/are locking up? After I installed my front discs, with an ECE kit, my rears would lock too easily...caled Dave at ECE to ask...he said rear wheel cylinder, pulled the drums and bam, both of them were toast. So make sure to check the wheel cylinders too.
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 08-26-2002, 04:42 PM   #5
Gordo
Smile
I'm with Project1970. In any case, around here that price for any kind of brake work sounds reasonable. In most cases people don't drive away for less than $600 in Connecticut in most shops. (It's sad but true)
1971 C10 swb stepside 350/700R4/3.73posi (retired as of 4/22/03)
1998 S10 short bed
2002 S10 Blazer
1942 Oldsmobile
1958 Massey Harris Pony
1951 Wife
Killingworth, Connecticut
May those who love us, love us, any of those who do not love us, may God turn their hearts.
And if God is unable to turn their hearts, may he turn their ankles so we may know them by their limping.
A man who works with his hands is a laborer; a man who works with his hands and his brain is a craftsman; but a man who works with his hands and his brain and his heart is an artist.
Gordo is offline   Reply With Quote
Old 08-26-2002, 05:15 PM   #6
jku72
Any brake fluid spilling onto the pads/shoes can cause "grabbing", and old sticky calipers can stay stuck on. This is common, if they drag, and get really hot, it may well be the caliper needs an overhaul/changeout.
Leaking wheel cylinders can cause than sudden grab and lockup, then you let off the brake and your okay again.
Sticky calipers brake on, then stays on after you let off the brake. If after driving, the wheel rim is very hot, I suspect caliper.
jku Cornville, Maine
68 C10 burb
42 Willys MB
46 Dodge WF-32 1.5 ton
53 & 56 Olds'
60 Cadillac
22 Dodge Brothers
jku72 is offline   Reply With Quote
