My Mistress the Sea
Power Steering gearbox replacement
Hi all,,,
I have what I think is a power steering gearbox going south really quick. The truck is wandering badly on the road. I have a few direct questions... Can the power steering gearbox cause instant failure? For example if I'm on the highway will it totally fail and I crash and die? Drastic I know but the truck is whipping around pretty bad with the trailer attached. Tongue wieght isn't an issue as it does it unloaded and rides pretty flat. For a replacement should I go with a rebuild unit or a new one? I searched and found this about the summit aftermarket one. What would be the difference? I read my maintenance manual and I believe it states that my truck has a varible gearbox now. Would I notice a big difference like a 1970 truck owner would? Truck is: 1971 K20 350/350 Thanks!!!
,,,they'd look alot better as beer cans... '71 K20 350/350 Rusty but trusty... gone '70 C20... gone '88 K1500... gone '90 C1500... gone '91 C2500... gone '95 C3500 6.5L Dually love this one!... |
My Mistress the Sea
Still hoping for some help...
Updated info is that the steering seems to be less loose during a longer drive. Not totally gone, but less sloppy. I've checked the fluid level several times and it's good. A question about the adjustment on top of the gearbox. I've been told that this adjustment can really help wandering problems. But you can go too far and cause problems. I understand that you loosen the lock nut and adjust the allen head part. Anyone have any pointers on that part??? Thanks!!!
is it just losing fluid through a broken seal, or is something wrong with the gears in there? fluid leaks won't cause a crash.
PROUD TO BE A MEMBER
I have the same problem ,after to many hours and one pitman arm later i am sure i need to replace steering box .i have about a 10 degree slop in my power steering and it drives my crazy .heres a couple places to read more i have found hope, they help you.
http://www.classicperform.com/tech.htm http://www.discountsteering.com/ http://www.google.com/search?hl=en&q...=Google+Search |
