09-30-2005, 12:02 AM | #1 |
What is this noise from..
Its coming from the front end somewhere when you go up hills and/or press the throttle down it goes sqweeeeeeeeek or schreachhhhhhh it sounds bad and is getting worse? any clues was just a little sqweek but now its way longer,, could the wet weather have anything to do with this? sounded like my chihuahua was stuck in the engine, like a small high pitched "yipe"..
1980 GMC Sierra Stepside. 350 V8... yahoo where on the road... 1994 chevy 6.5 td 2500. 250,k good truck, cracked heads.. motor getting rebuilt, should be running by monday.. finger xrossed........... |
09-30-2005, 01:05 AM | #2 |
I'm back with 2nd truck!
Sounds like a belt to me. Check the belts when you rev up the engine. Other than that it could be a bad joint on the bushings going out but hard to say without there listening to it. If it does it while driving only and not in park it may not be a belt then.
1979 Chevrolet Bonanza Big10 "Tootsie Roll" 1985 Chevrolet Silverado (wife's) Member of the Southern Bowties Club "Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson |
09-30-2005, 01:16 PM | #3 |
'87 V20 4x4
sometimes the belts will give a little when under load esp if its wet out and they may need tightened up ir replaced but I agree totally with 79big10 its hard to say without hearing it hes right in it may be a joint esp a ball joint good luck and let us know what you find out
Doc
'86 K5 Blazer 4x4 FOR SALE '87 v20 4X4 '99 S10 Blazer 4X4 |
09-30-2005, 03:19 PM | #4 |
Belts need tightening or replacement. Could also be a small chipmunk under the accelerator pedal......
86 SWB 9.0 LITER T-400-OD 4.11 eaton-4/5 drop Best 1/4 12.51 @112mph no traction |
09-30-2005, 05:34 PM | #5 |
Today is alot dryer and hasnt made that noise only when you hit the gas and go up hills.. not while its idleing though.. it still does it but not as long. like in the rain yesterday....
how do you tighten a belt? ( sorry dumb question but i am of the female species..) I know how to take the engine apart but just trying to think wear youd adjust a belt? hmmmmmmmmmmmmmmmm????? could it be the heater?
09-30-2005, 05:40 PM | #6 |
Oh yea i have another question about the 350 again, i took the dist off. now it will be out of time. correct, how do i get it so that its back in time? so that they line up proper ? do you have to turn it till you see the dist parts moving?? dont understand how it got out of time in the first place.. .. I see your on here 79big10 i think you know what i am talking about..thanks
09-30-2005, 05:48 PM | #7 | |
They should have taught you that in engine take-apart school. I doubt that it is the heater. Bud
Current GM toys: 1983 Chevrolet K20 4x4, 2004.5 Chevrolet 2500HD LT Duramax 4x4 |
09-30-2005, 05:50 PM | #8 |
On the belts it depends on whayt belt(s) are loose. Check how much play are in them by looking here http://www.ehow.com/how_109_check-belts.html Then you can see where the bolts are that hold in place the item(s) that are attached to the belt. As on the alternator you can see 2 bolts holding it on. One at the top and one at the bottom left. Loosen both to where you can move the alt. and get a prybar and force it between the alt. and something else to tighten up the belt. I usually use the cover bracket. Try not to use the water pump since it can break off or the bolts mounting it it. Once you have the alt. belt tight then screw back in the bolts.
On the power steering bolts you need to do the same thing but make sure not to stick it by the reservoir since it can and will crack Same situation as before loosen and pry then tighten. On the distributor this site has great step by step http://73-87.com/7387garage/drivetrain/disremov.htm
09-30-2005, 05:52 PM | #9 | |
09-30-2005, 06:27 PM | #10 |
This is my engine take apart school... i am learning everything from u guys so teach me right the first time k....... quick learner.. no worries.. thanks for the info.. Jenn let u know how it works out..
09-30-2005, 06:43 PM | #11 |
oh crap.. i shoulda left the old dist on.. I never marked anything.. looks like that is going to be the hardest part on reinstalling this engine........
09-30-2005, 08:28 PM | #12 |
Professional Grade
It isn't too tough
However, one peice of advice, when you are turning the engine by hand to line up the timing mark, don't use a breaker bar on the bolt in the center of the balancer. If you snap that off, you are in biiiig do-do Try your best to turn it by hand by pulling all the spark plugs out, then turning the balancer without using tools, if you haven't got the strength, then use a breaker arm, but use it on one of the bolts that hold the V-belt pulley to the balancer. Its far easier to replace a balancer that has a stripped out bolt hole, or a broken bolt in it than it is to replace / repair a busted crank snout bolt. Also, if you have a compression tester that screws into the spark plug hole, pull the gauge off, then route the opening to the front of the engine, that way, when you get to the compression stroke like you need to be on, you'll hear the air blowing out of the compression tester's hose. Follow that tutorial on 73-87.com to the T, and you'll be just fine Oh, and if you do stick the dizzy in backwards, don't worry about it. I have yet to install a dizzy in properly the first time, and I've done it a fair number of times, lol It won't hurt your engine, just make it backfire out of the carb Trust me, you'll notice right away when a fireball comes outta your carb, lol, have a fire extiguisher nearby incase someone catches on fire if that happens, most of the time it'll just go POOF, and vanish, but other times something flammable like that fabric on the bottom side of the hood might start up.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
09-30-2005, 10:50 PM | #13 |
haha i already burnt a truck by back fire before I know whats its all about..I think that was my 84 chevy,SB,, was such a good truck.. no muffler and the passenger side door i had to tye shut,,, too funny..
i found out more on my diesel, the first mechanics that worked on it ,(long story) torched the manifolds and wrecked the seals and bolts and stuff, i would have had it back today but now there waiting on more parts.. more money. sheesh..if a mechanic F***'s up at his shop is he responsible for replacing those parts??? .whats the dizzy? better find that out..lol
10-01-2005, 12:09 AM | #14 |
LOL Dizzy is short for Distributor also same thing is called HEI as well.
10-01-2005, 11:12 AM | #15 |
oh.. i am not up on the mech slang yet.. lol thanks..........J
