Old 10-06-2005, 03:58 AM   #1
68_396Noel
Can I put a 5 speed in my 68 chev???
my buddy wants to put a 5 speed in his 68 chev and wants to know what tranny to use and to match up to a 205 t case
68_396Noel is offline   Reply With Quote
Old 10-06-2005, 08:54 AM   #2
truckdude239
truckdude239's Avatar
if you find out let me know i want to switch my 3 speed to an 5 speed i have an 1971 chevy c-10 which i got to go pick up here in an hour or so
Old 10-06-2005, 12:30 PM   #3
Americanrider
1. Look for a NV 4500 from a GM 4x4. They have a 32 spline rear shaft and round 6 bolt mounting pattern. Market price of $700-1500
2.Then look for a NP 205 used behind later model SM465 trannies and later TH400 trannies, from about '85 to '91 in straight axle 1-ton trucks. The best find is the "long" 32 spline female input gear. This is far less common than the "short" 32 spline input, but is as strong and durable. This gear will stick out of the 205 case by about 3 1/2". Market price of $250-600
3. If you can't find a long 32 shaft get a short 32 shaft with the round 6 mounting pattern. Proper shaft stickout from the TH400 is 2 1/2". Market price same as above.
4. Join them together with parts form Advanced Adapters. They carry Bellhousing kits and eveything you need to make it work. You sould be able to do it for less than 2 grand. Depending on condition of the the parts and how hard you shop around. They have kits to mount up the figure 8 transfer cases but they cost more that buying a good used round 6 type transfer.
5. Enjoy the .73 overdrive and better gas milage in 5th gear.
PICS NP 205 output gears left to right:
32 spline "short", 32 spline "long", 10 spline with a worn drivesleeve, 27 spline with a new drivesleeve.
Americanrider is offline   Reply With Quote
Old 10-06-2005, 12:50 PM   #4
mrein3
mrein3's Avatar
I'm not knocking the swap but even at $3 per gallon, you can buy a lot of gas for what that 5-speed will cost you in a 4x4.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 10-06-2005, 06:05 PM   #5
Americanrider
If I wanted milage I'd drive a 2wd w/ a 6cly... to each his own.
Old 10-06-2005, 07:03 PM   #6
Maximum Overdrive
December 21, 2012
A person can do anything they want as long as they have the skills to do it. Over 18 years ago I put a 455 Pontiac in a 69 GMC. That truck screamed like a raped ape.
"!Ama Sua, Ama Kjella, Ama Lllulla!"
Maximum Overdrive is offline   Reply With Quote
