Old 08-27-2002, 03:20 PM   #1
Crank
Crank's Avatar
Gettin a 400 sbc
I have a 283 sittin' in a 84 camaro. But last night I talked to my brother, I've currently been pestering to get his 400; well he told me he'd give me the 400 short block minus the crank for the 283. Hehe. The heart buildup begins. Muahaha(evil laugh) although I'll be building the motor on a part time job account I have big dreams. But Later i gotta call my brother and get the casting #'s if someone could run em for me it'd be cool. Well if anyone has any advice or tips post em. Thanks. Brandon
Crank is offline   Reply With Quote
Old 08-27-2002, 07:10 PM   #2
dmec
dmec's Avatar
it you dont get the crank with the shortblock forget it. they are 1 of a kind and hard to find.
dmec is offline   Reply With Quote
Old 08-27-2002, 07:55 PM   #3
chevy lover
HMMMM Chevy
chevy lover's Avatar
Cracks you can get. Just decide what you want to do with that 400. I have one also without crank and that suites me just fine. When I'm ready I'm stroking it, meaning I got to get my hands on a 350 crank. Check your local speed shop, they can get the crank you want.
chevy lover is offline   Reply With Quote
Old 08-27-2002, 08:00 PM   #4
Jwill41
Jwill41's Avatar
i thought when you "stroked it", it was a 400 crank in a 350 block.
http://www.picturetrail.com/jwill41
67 1/2 ton GMC short step side
68 1/2 ton Chevy long fleet side
72 1/2 ton Chevy Suburban
99 1/2 ton Chevy Suburban
founder (and only member) of the primer/clearcoat club
Jwill41 is offline   Reply With Quote
Old 08-27-2002, 08:15 PM   #5
brad69C-10
Stroking it would be a 350 block and a 400 crank, or for that matter, any crank with a larger stroke than a 350 had to start with.....Destroking would be like using a 350 crank in a 400 block...........
69 C-10 Pro Street...........red on black...........big block and a lot of go fast stuff under the hood
Still in progress ...........
brad69C-10 is offline   Reply With Quote
Old 08-27-2002, 08:31 PM   #6
racedvl
racedvl's Avatar
Thumbs up
You could actually stroke it!!! Hehehe......
http://www.speedomotive.com/500_hp_maxi_mouse.htm
racedvl is offline   Reply With Quote
Old 08-27-2002, 08:56 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
You could destroke it, but that would make the inherit RMP character worse for the street. Destroking it would turn it into a high RPM screamer...but boooooring in the lower RPMs.
Even on a budget buildup, you can have fun...esp when you have all those cubes to play with.
Build a good stout botom end. If you don't plan on spinning the snot out of it (snot is 5500 RPM and higher) then you can get away with stock stuff.
Shave what ever heads you have on it (882's most likely) ensure they are unleaded gas friendly, and make sure the steam holes are there.
Put in a good RV cam or even a step over the RV specs, somethign with low to mid range power. Then, your typical bolt ons like the must have HEI, a good flowing daul plane intake, carb name of your liking and a good set of headers.
If you pay attention to detail, and shop carefully (used helps ALOT) you can do this for about $1000 if you have the time to streach out the build up. (deals come and go, you gotta jump on them when they show up)
Something like this can/should last 85,000 miles if driven real hard, (below the snot RPMs) and 100k or more if taken care of.
Most importanly, it will be fun since the power band will be the same that it stays in 99% of the time.
Old 08-27-2002, 09:22 PM   #8
chevy lover
HMMMM Chevy
oops my mistake.
sorry for the ignorance but what is a longhorn?
OFF Topic too
Old 08-27-2002, 09:37 PM   #9
Crank
Crank's Avatar
A longhorn is an 8' bed on it, with another 9" added to the front of the bed. I thought it was another 12" but i think it was longhornmail who enlightened me. Thanks everyone for the input. If you have any more ideas let me know. Also my brother did suggest the destroking it idea but i really dont wanna go down in cubes. So i think Ima have it bored 0.030 over and go with a cast or, if i can get the cash a forged crank and good pistons and rods; and begin after that.
Thanks. Brandon
Old 08-27-2002, 09:46 PM   #10
Longhorn Man
Actually, it is only streached 6 inches...at the front of the bed.
Check out the link in my signiture, I have all the nity gritty in that site...be warned though, lots of stupid pop ups.
Old 08-27-2002, 09:51 PM   #11
Crank
Crank's Avatar
Oops, sorry longhorn. I guess i didnt remember right or was told wrong but not to discredit you at all. sorry. But anyway i have an engine masters magazine. It has a 383 stroker but it has a 1.6 ratio rocker on the exhaust side and a 1.5 ratio on the intake side. It says it give it more exhaust duration and makes the motor breath better and run better. Does this also work on the 400. I'd think it would. Thanks
Old 08-29-2002, 10:00 AM   #12
chevy lover
HMMMM Chevy
Longhornmail
The death of your truck!!!
Sad man, that was a nice looking truck. Your story hit home too. My first truck was a 71 GMC 3/4 ton pickup. My wife was driving and on her way to see me at work. It was raining, at dusk and it was a small chevy stationwagon. The law here is if it is raining enough to have your wipers on your lights must be on also. Well my wife got the ticket for running a stop sign. The damage to the truck was almost identical. I found a frame and fixed the truck but it was never the same. It was a sad day.
