Old 10-06-2005, 03:42 PM   #1
motocrosschump
Door not Stopping
My driver side door opens up so far that its hitting the front left fender. What is the fix?
2006 Titan SE Crew Cab Daily Driver
2005 Mazda Tribute (Wifes car)
1969 C10 SWB 350/3 Fleet "Max"
1969 Chevelle 2 door 350/3
motocrosschump is offline   Reply With Quote
Old 10-06-2005, 03:44 PM   #2
Putter
More Cowbell....
Putter's Avatar
Get a good bungie-cord!!!
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 10-06-2005, 03:55 PM   #3
67ChevyRedneck
67ChevyRedneck's Avatar
There's supposed to be a "stopper bar thingy" (yes, that's a technical term) on the top door hinge, take a peek at your passenger side door. You may need to replace your door hinge, as I'm not sure if you can buy the "stopper bar thingy" seperatley
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 10-06-2005, 04:31 PM   #4
Fred T
Cantankerous Geezer
Fred T's Avatar
You have to replace the hinge, the stop is integral.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 10-06-2005, 05:04 PM   #5
demi
demi's Avatar
You can actually replace the hinge stop without removing the hinge. If you have an old hinge with a good stop and you can fit your hand inside the door, you can:
1. drive out the roll pin
2. remove the metal stop piece from inside the door and
3. remove the little hard vinyl like pads.
Install in the reverse order. I replaced both of mine in this way.
Hope this helps.
demi is offline   Reply With Quote
Old 10-06-2005, 05:44 PM   #6
motocrosschump
Thanks Demi
Old 10-06-2005, 06:42 PM   #7
68 short step
install a door stop on your fender to protect it in the mean time, you may have to drill a pilot hole to get the screw started first tho.
68 short step is offline   Reply With Quote
Old 10-06-2005, 09:03 PM   #8
KEH
Better late than never
KEH's Avatar
That is a great "how to" demi. I need to do this because my doors don't stay open when a park on even the slightest upgrade.
This post should go in the FAQ section.
1970 C/10 SWB Stepside
KEH is offline   Reply With Quote
