Old 10-07-2005, 10:57 PM   #1
Dano69c10
Dano69c10's Avatar
Exclamation HELP! External to internal voltage regulator/alt swap
I was doing the external voltage regulator / alternator to internal voltage regulator/ alternator swap that is in the FAQ section and ran into a problem.
I have the red, white and blue wires he mentions in the FAQ, but I also have a black wire that was connected to the small post on the back of the old alternator. Where does this black wire hook up to?
I hooked up the blue wire to the #1 tab (driver-side tab) on the new alternator and the red wire to the post on the back of the new alternator, and then I ran a jumper from the big post to the #2 tab (passenger-side tab) on the new alternator. I just capped the white wire.
I am just wondering what the black wire that was hooked to the small post on the old alternator did and what I should do with it on the new set-up?
Help! I don't want to run the truck until this is remedied. If I read the FAQ wrong and did the wrong wire hookups please advise.
Thanx in advance
Dano
'69 Fleet
It ain't yours, if you didn't build it!
Dano69c10 is offline   Reply With Quote
Old 10-07-2005, 11:41 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
been so long I can't remember the colors and locations... I actually took my harness apart and removed something like 20 ft of wire when i update4d to an int reg unit.
Your black wire is a ground... I do remember grounding it to a mounting bolt when I did my last truck.
Old 10-07-2005, 11:46 PM   #3
VetteVet
Msgt USAF Ret
VetteVet's Avatar
alternator wiring
Here is a website that shows how to wire the new alternator . I bekieve you have the blue wire and the short red wire going to the same terminal on the alternator unless I misread your post. The blue wire goes to the turn on terminal that energizes the field and the red wire goes to the internal regulator that senses system voltage. If I remember correctly the red wire is nearest the large terminal.
http://www.chevelles.com/techref/tecref14.html
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 10-08-2005, 12:31 AM   #4
matt67350
matt67350's Avatar
Got this from www.oldengine.cor/unfaq/10si.htm
1 The large "BATT" terminal which gets conected to your battery positive.
Run a new 10 gage wire to the battery positive.
Get a repair pig-tail plug from the auto parts store to connect the wires to the
alternator
2 The #1 Terminal. (Marked with a "1" on the case of the alternator)
This terminal is used to connect to the dash light. Us the
brown wire from the wiring harness here.
3 The #2 Terminal. (Marked with a "2" on the case of the alternator)
This terminal is used to exite the 10si into operation. Connect it to the "Batt"
on the Alternator.
4 You can discard the rest ot the wires or just tape them out of the way.
I have converted several truck and this works great.
Good luck,
Matthew
matt67350 is offline   Reply With Quote
Old 10-09-2005, 01:21 AM   #5
Dano69c10
Dano69c10's Avatar
Thanx for the responses everyone!
I hooked the black wire to the bolt on the alt case for ground. (like "RageNRat" did on the FAQ page)
I wanted to keep using the rubber boot for the big post on the alt, so I ran the red jumper wire through the boot also.
Truck fire up fine, ammeter is looking good and no one can tell I swithched over becuase it looks like a stock set-up.
The only money I spent was on the alternator and the alt plug for the tabs.
This conversion took me about one-hour total, I highly recommend it!
Hope this thread helps someone else out.
Dano
For sale one alternator and voltage regulator, cheap.
'69 Fleet
