Old 10-08-2005, 03:38 PM   #1
76bonanza
76bonanza's Avatar
help
changing oring on fuel sender the tab on the oring does it go in any speacial way?
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 10-08-2005, 06:28 PM   #2
76bonanza
76bonanza's Avatar
sender still leaking for like 5 minutes after fill up looks like it is leaking from the fuel line were it goes thru the sender?
1968 c10
lowered 3" 4"
Old 10-08-2005, 08:19 PM   #3
JimKshortstep4x4
Talking
It sounds like the solder joint is leaking. If you remove the sender and clean all the gasoline off of it they can be resoldered fairly easy.
Jim
Old 10-08-2005, 08:22 PM   #4
76bonanza
76bonanza's Avatar
what is the solder joint? is the fuel line supposed to move?
1968 c10
lowered 3" 4"
Old 10-08-2005, 08:43 PM   #5
walker
walker's Avatar
Fuel line shouild not move, sounds like the solder joint, where the fuel line goes through the plate that goes onto the fuel tanks has gone bad. This would account for your other trouble of the float banging against the tank. You would need to clean the fuel residue off and resolder the joint. I am not sure what type of solder is in the joint now, but I would imagine it is a silver solder, or perhaps a silicon bronze brazing rod may do the trick.
Andy,Phx AZ
'67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...)
"23 C-Cab-sold
'48 Ford 8N tractor(still working)
'67 Scout(Now on the road)
'70 MG B.-sold
walker is offline   Reply With Quote
