10-01-2005, 10:22 PM | #1 |
72 BB C30 Super LongHorn
LongBed weight for removal?
Does anyone know the actual weight of these beds?
I am building some 4X4 to place under the bed to allow for the frame to roll out forward... I was looking at some caster wheels and some are rated at 200 lbs and some are at 175 lbs...just want something enough to roll it fore and aft and not too far along.... Thoughts?
72 BB C/30 Longhorn Super HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM HO72 build : http://67-72chevytrucks.com/vboard/s...d.php?t=714492 2017 SS Last edited by RPOZ11; 10-01-2005 at 10:51 PM. |
10-01-2005, 10:37 PM | #2 |
Just a guess is 300 to 400 lbs. Over Labor Day weekend 2 men & a boy (myself,
another grown man & his son), lifted a '71 longbed from a rolling dolley into the back of my box van.
rwgregory 67 GMC 2500 ,2w/d wide box 305 V-6, 4-speed |
10-01-2005, 10:37 PM | #3 |
Either wheels should be fine, IMO.
72 Chevy 4x4 350 55 Chevy Bel Air 350/350 53 Matchless G80s (motorcycle) 06 Trailblazer SS 400hp LS2 |
10-01-2005, 11:21 PM | #4 |
I can tilt one up on end by myself, probably about 3-350
10-01-2005, 11:29 PM | #5 |
I considered this but, well, I wanted to save the end of the bed and my frame is forward to do this at the moment.
Am uncertain if the side bed walls are strong enuff to support the entire wieght if I place 4X4's under the side bed panels...Am considering going under the bed thru the wheel openings... Ill see what I can do I supppose...I am figuring that the 4X4 is plenty strong enuff to support it!
72 BB C/30 Longhorn Super HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM HO72 build : http://67-72chevytrucks.com/vboard/s...d.php?t=714492 2017 SS |
10-01-2005, 11:30 PM | #6 |
me and one buddy picked mine up and moved but its kinda front heavy. so be careful it wants to tip forward
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
10-01-2005, 11:45 PM | #7 |
I would set your dollies up so the weight could be supported on the bottom of the bed, not the sides. If you have the room. When you take it off set things up so you can "walk" the whole works backwards off the truck. But before you take it off block the rear end and remove the back wheels from the truck ( if you know what I mean) With the wheels off you don't have to lift it so high ( to clear the tires in fron of the whells wells) and the tires don't trip you as you shuffle walk backwards. It worked real slick for me & a couple buddies. ps Be sure to remove your tail light plug!!!!!!!!!!!
I got a bench seat baby, you don't have to sit over there. |
10-02-2005, 12:10 AM | #8 | |
As you can see I am limited with space to the rear of the frame... so, trying to go straight up, then wide with some 4X4's I am attempting to clear the rear axle as I can't get it out due to very stubborn bolts!
72 BB C/30 Longhorn Super HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM HO72 build : http://67-72chevytrucks.com/vboard/s...d.php?t=714492 2017 SS Last edited by RPOZ11; 10-02-2005 at 12:11 AM. |
10-09-2005, 06:29 PM | #9 |
Bed cart made
Here's what I created to get around removing the bed off of the frame.
I was limited with space as I have WAY too much stuff, so, this allows me to roll the bed over the frame and rear axle... all costs were at $100.00 4 4X4 cedar lengths, 2 were cut to fab the legs 2 lengths of 8' 2X4, for the supports throughout Simpson braces, nails, and 125lb metal wheels casters Took all of about 5 hours to assemble Dont expect this to be like metal, it does move a little bit, but if you are slow and patient, it works just fine! Support the bed accordingly, tends to want to drift from side to side when I lifted it front and back!
72 BB C/30 Longhorn Super HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM HO72 build : http://67-72chevytrucks.com/vboard/s...d.php?t=714492 2017 SS Last edited by RPOZ11; 10-09-2005 at 06:35 PM. |
10-09-2005, 06:31 PM | #10 |
I still need to support the upper 4X4's under the 90* so to keep it from flexing!
