Old 10-02-2005, 10:43 PM   #1
bud45
16" wheels for '69?
Just wondering: my '69 GMC with drum/drum brakes and 6-lug wheels are running 15" tires now...will late-model 16" wheels fit the old pattern and will their offset give me clearance around the coil suspension? Thanks, Bud
bud45 is offline   Reply With Quote
Old 10-02-2005, 10:48 PM   #2
pissonNOS
senior member
pissonNOS's Avatar
i think the only problem you might run into is the hole in the middle might be too small
69 GMC bagged
pissonNOS is offline   Reply With Quote
Old 10-02-2005, 10:48 PM   #3
llegos
from what i hear, there is something different that wont work right with newer style rims....i wanted to get some too, but people said they wouldnt fit
-Steve
llegos is offline   Reply With Quote
Old 10-03-2005, 01:34 AM   #4
jsbgump
Gone Fishing
jsbgump's Avatar
The only real problem is the center hub hole is too small. You would have to waller it out a little bit to work.
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 10-03-2005, 09:34 AM   #5
Hart_Rod
Hart_Rod's Avatar
Front hubs are too large. You will have to take the wheels to a machine shop to have the hole enlarged. I have a set off of a 03 Suburban. Where are you located?
Rob
Hart_Rod is offline   Reply With Quote
Old 10-03-2005, 09:43 AM   #6
motocrosschump
Offset is wrong..
Hole is too small
Your wheels(if aluminum) will rub on the control arm. Trust me been there.
2006 Titan SE Crew Cab Daily Driver
2005 Mazda Tribute (Wifes car)
1969 C10 SWB 350/3 Fleet "Max"
1969 Chevelle 2 door 350/3
motocrosschump is offline   Reply With Quote
Old 10-09-2005, 10:44 PM   #7
bud45
Rob, I'm in Satsuma, AL, just north of Mobile, AL...is it much trouble to enlarge the holes with a some sort of grinder wheel? I also had someone at a local salvage yard say that they thought some aftermarket Isuzu wheels would fit. Thanks, Bud
Old 10-10-2005, 09:12 AM   #8
Hart_Rod
Hart_Rod's Avatar
Bud,
You only have to enlarge the 2 front wheels (all 4 if you wanted to rotate them). You would have to be very careful doing them yourself, I would suggest getting a quote from a machine shop first. Let me know.
Rob
Old 10-10-2005, 11:26 AM   #9
chevyfarmer
chevyfarmer's Avatar
I am not able to figure out if you guys are talking aluminum or steel wheels. I had the centers of a set of steel wheels enlarged by a machine shop for 15 bucks a rim, just to let you know.
67 short wide 355ci 3 on tree
69 short wide 250ci 3 on tree
68 long wide 283 3 on tree
72 2wd Blazer project 454 5 speed
chevyfarmer is offline   Reply With Quote
Old 10-10-2005, 12:39 PM   #10
Hart_Rod
Hart_Rod's Avatar
Aluminum wheels like these.
