Old 10-10-2005, 10:39 AM   #1
FirstGen
Just Don't Stop!
FirstGen's Avatar
Can someone measure the inside width of the wheeltub on a fleetside for me?
I just want to know the width of a fleetside bed stock. Like the dimension from the inner tub to the inner lip of the outer fender. I was wondering if there is any truth to the fleetsides have a more room than the stepside claim.
1968 C10 build in process
TT LSA/6L90e/9"
FirstGen is offline   Reply With Quote
Old 10-10-2005, 12:23 PM   #2
SCOTI
SCOTI's Avatar
FirstGen, they should be the same between the tubs. I can tget a measurement on my 68 after work for you if somebody doesn't beat me to it before then.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-10-2005, 12:27 PM   #3
FirstGen
Just Don't Stop!
FirstGen's Avatar
I wonder what it would look like to tub a step side using fleet wheel tubs? I'm sure someone has done this, anyone have a pic?
Thanks Scoti!
TT LSA/6L90e/9"
Old 10-10-2005, 02:22 PM   #4
SCOTI
SCOTI's Avatar
Thanks Scoti!
It looks good & is actually pretty easy. Extremely cheap way to stuff rubber under these trucks IMO (well.... much cheaper than tubbing a fleetside truck).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-10-2005, 03:49 PM   #5
kndall
kndall's Avatar
just under 13" from inside edge of wheel tub to inside edge of bedside along arch. The inside of the bedside angles inward above the wheel arch and I didn't have a flashlight to look up in wheelwell to read tape. Hope it helps.
kndall is offline   Reply With Quote
Old 10-10-2005, 04:26 PM   #6
FirstGen
Just Don't Stop!
FirstGen's Avatar
thanks for the reply. I think I will just use fleetside tubs. Scoti, do you have a set you want to sell me?
Thanks,
Taylor
TT LSA/6L90e/9"
Old 10-11-2005, 05:37 AM   #7
Purs
Got Big Block?
Purs's Avatar
First Gen, I've got a set. I'll email you some pics in the morning. Bad luck though, I just met up with a guy from Dallas (on Saturday) and swapped 12 bolts (car) that could've brought them back to you....
"Experience is what you get when you didn't get what you wanted."
Purs is offline   Reply With Quote
