Old 10-11-2005, 07:40 PM   #1
heldonss
Help with Temp guage
I have a problem with my temp gauge. I have 2 GM gauges and one Repop...same problem. I have had 2 sending units....both are suppose to be for gauges. My problem is that the needle goes to the Hot side. I just put the new Repop in and soon after I started my truck it went Hot. Any help is appreciated.
454 with aluminum heads.
Factory gauges.
Painless wiring.
Current rides:
2007 Silverado VortecMax 1500
2007 Silverado Classic 1500
2004 GTO, 6spd
2003 Silverado 3500, 8.1 w/ Allison
2002 Camaro SS, 35th Ann., 6spd
2002 Silverado 2500, 6.0
1999 Buick Regal GS, 3800 SC
1997 Camaro Z28, 30th Ann. convertible
1991 GMC Syclone, #170 of 2998
1990 454 SS, 26,000 miles
1987 GMC 3500 Box Van
1972 Chevy C-10 short bed
1970 GMC Sierra Grande..2 owner
1968 Camaro RS/SS, 396/375 HP
1967 Chevy II Nova
1967 Camaro Convertible
1957 Chevy Truck
heldonss is offline   Reply With Quote
Old 10-11-2005, 07:57 PM   #2
pjmoreland
pjmoreland's Avatar
Sounds like the green wire that runs from the sending unit to the gauge is probably shorted to ground somewhere. If the wire is shorted, the needle should move to "H" as soon as you turn your key to the "ON" position even if your engine isn't running.
Try unplugging the wire from your sending unit, and then turn the key on. If the gauge still goes to "H" then the wire is probably shorted. If the gauge doesn't go to "H" then your sending unit is most likely bad.
pjmoreland is offline   Reply With Quote
Old 10-11-2005, 08:00 PM   #3
byrd
Union Electrician
byrd's Avatar
if you have a continuity tester you could check the wire to ground to see if it is grounded out and then all you would have to do then is find the short
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 10-11-2005, 08:01 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Exactly. Folow the wire from the firewall to the sending unit. It is probably melted on an exhaust manifold or something.
