Old 10-13-2005, 06:25 PM   #1
muddpile
muddpile's Avatar
Column Shifter Knob?
Has anyone ever changed the knob on a factory column shifter? The stock smooth black one looks alright, but if I could put an aftermarket ball on it that would be pretty cool too. How would I get the old one off and put the new one on? Thanks!
muddpile is offline   Reply With Quote
Old 10-13-2005, 07:23 PM   #2
70GMCer
70GMCer's Avatar
I just pulled mine off.......It can be kinda tight, but does pull off......The shift handle itself, has a rib edge on it that helps hold the plastic knob on tight......Putting the new one on depends on how the new one is made. Get the old one off first, and then compare the two......
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 10-13-2005, 07:37 PM   #3
Mongo
YES_____NO
Mongo's Avatar
Another trick it to pull your shifter off the column. Then heat it up near the knob with a heat gun. it will pull off much easier. Oh and be sure to wear gloves the shifter arm get a little too hot to hold with bear hands.... believe me I know.
People many not remember what you said or what you did, but they will remember the way you made them feel. - unknown
Cause, remember: no matter where you go... there you are. - Buckaroo Banzai 1984
Help support the board
Mongo is offline   Reply With Quote
Old 10-13-2005, 09:37 PM   #4
powell72
powell72's Avatar
I put an Ididit billet knob on my stock lever, totally changed the look of it.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
