![]() Join Date: Jul 2004
Mystery wire under my hood
Anybody know where this wire should go? It's a tan wire coming out of the harness in the firewall gutter. It has a 90 degree plugin connector with a 12 inch pigtail pulled into it. The other end of the pigtail is broken off and it's just hanging loose.
![]() Last edited by 71Shortbed; 10-14-2005 at 07:34 PM. |
Looks like it goes to the plug on the proportioning valve?
![]() ![]() ![]() LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! ![]() ![]() |
Ohio is right but I think your proportioning valve is a replacement and doesn't appear to have the brake warning switch.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. ![]() ![]() ![]() |
![]() Join Date: Jan 2002
72 2wd 307/AT/AC/TILT WHEEL 78 JIMMY HIGH SIERRA |
Thanks guys. That explains why my warning light never comes on.
![]() Join Date: Aug 2003
P Valve
Looks like a drum brake P valve to me.
I checked it and there is a rubber wire connecter on the bottom of the valve. You can see part of it in the picture. I guess I'll hook the sucker up.
its all about the +6 inches
I was going to recomend looking there for it...
How can one tell if it is a drum distrabution valve, or a disc/drum proportioning valve? |
![]() ![]() Join Date: Jan 2005
It looks like the drum/drum proportioning valve that was on my '67. My '72 has a disk/drum proportioning valve that is way bigger than that and has a little rubber cap in the front of it. Also the front brake line attaches to the bottom of the proportioning valve instead of the front.
well hot dam... I didn't know they looked so different. cool.
Designated A-hole!
Learn something new everyday.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
I was going to say that the prop. valve in the pic looked like the one I had on mine (all drum) before I changed it to drum/disk. Well Andy, at least ya learned something today? So it's not entirely wasted?
![]() ![]() ![]() LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! ![]() ![]() Last edited by OhioDan; 10-15-2005 at 10:22 AM. |
Re: Mystery wire under my hood
Yeah, but I was trying soooo hard NOT to learn anything today!
